Do I need a BEC
RE: Do I need a BEC
Any time you have over 9cells or 10volts, you HAVE to have a bec. Most ESC's can regulate your system down to a safe 6-7volts but when you go higher in voltage the Built in BEC on most ESC's will drop your voltage to an unusable level. That is a mathmatical function of the builtin BEC, so a dedicated BEC will do a much better job of regulating power to the reciever and servo.
Good luck and have fun!!
