TL-01B... crawler?
TL-01B... crawler?
Hi,
i'm not usually one to spend 400 bucks on something i may end up not liking, so I thought I could be resourceful.
I have an array of TL-01 parts, and i'm about to build a TL-01B with mass ground clearance. Thing I wanna know is if the lack of gearing options is going to be a hassle? i would think that a set of normal-speed tamiya gears and a 19t pinion combined with a very, very, very high turn lathe motor would do the trick.
just so the people with a little less imagination can read:
Will normal gearing be too low (fast) for use with a 40-80 turn motor?
Do 1.9" or 2.2" tyres and rims fit normal sized 1/10 hex-drives?
If you don't actually have answers to these questions, or you're just gonna try talk me into an ax-10 or cr-01, turn off your computer and re-think your hobby
RE: TL-01B... crawler?
I have tried this...
I used a HBX Bonzer and used a HPI X-35T Motor and well the problem is, the TL-01 chassis really doesn't offer too much in the way of suspension..
I used 75mm Shocks and when I went to 80mm, the dog bones kept falling out...
Those TL-01s might make a decent "trail" rig, but the problem I see is that you're trying to get something to work like an AX-10 and just isn't designed for crawling. You're selling yourself short. The TL-01 is gonna be mediocre at best and isn't going to give you any idea of what a true crawler is capable of.
Yes... a Decent Trail rig is correct... they do go some pretty cool places...
http://www.youtube.com/watch?v=xxSrHhfzkgw
this is where i get confused.
as i've already done it.
and it works. only problem i'm encountering is that it tips quite easily at 75°, and i'm pretty much cooking the little silver can i've been experimenting with. 70t motor is the next step.
if i could get some pics, i would.
kb, i'm not selling myself short. because, i had all of the parts sitting around. i used the wheels and tyres from my slash, pretty much everything from a TL-01b apart from the shocks which are from the front end of a schumacher cat. i also didn't want an ax-10. i know how they work. i wanted mid-level and easy and fun and cheap.
wondering if it's possible to run a smaller pinion than 19t?
