esc suggestions for duel motors
i have a G-made Spider with the motors mounted to the axles front and back. what kind of esc can i use to power the motors (currently use evx out or am E MAXX) i am wanting to get a Novak rooster crawler edition, can i run both front and rear motors with that?
or any suggestions?
or any suggestions?
RE: esc suggestions for duel motors
I would also go with the Mamba Max. It can handle a ton of power. WAY more than you need for a crawler, but if ever want to hook up to batteries for extra voltage and more speed or use the ESC in something other than a crawler, you can't do that with the Novak Rooster Crawler. Plus the Mamba Max is programmable through your PC, which is a nice feature for programming drag brake and such.
