New Shocks for AX10?
TX
Anyone with suggestions on a good set of threaded shocks for my AX10?
I just mounted a set of new HBRovers with dual stage memory foam and the stock shocks just keep leaking and busting on me...
CA
RE: New Shocks for AX10?
I use the Losi shocks that are modded to fit the Axial... I cannot find the exact thread that talks about them, but they are pretty darn good. Also Axial makes a set of threaded aluminum ones now too, which are pretty nice looking. there are realistaically alot of ways you can go as far as shocks, and it all depends on what body/cage style you are going to run with.
Just read through the forums here and maybe check out RC Crawler lots of good info you just need to dig around and see what you find.
