axail scorpion drive shafts
Does anyone know of a longer driveshaft for the axial scorpion. I'm working on a way to lower and lengthen the truck, but when I do this the drive shafts seem like they'll be to short and may pop out under pressure.
Thanks KID EVIL!
Thanks KID EVIL!
RE: axail scorpion drive shafts
I don't know if any aftermarket ones are longer, but there is an old-school way to modify stock Axial driveshafts. It will require you to have an extra set of shafts. Basically, you lop the end of a female shaft off, so you have a hollow tube, and glue/epoxy it to a male shaft. Then you use another female shaft engage your longer male/female shaft.
There's something about all of this that just sounds... odd. Especially since all this is related to the, um, "tranny"...
Nevermind. Dumb joke. Forget the tranny comment. By epoxying the female end onto the male end, you can essentially lengthen the driveshaft about two inches or so. I can't tell you exactly since I've never used the modification, but I've seen it done and it seems to work. I could probably find a link on RCCrawler, but the site down at the moment.
EDIT:
Found it in the newbie section at RCC:
http://www.rccrawler.com/forum/showthread.php?t=41181
EDIT:
