Interested in building a Crawler
MT
RE: Interested in building a Crawler
Its all about what you want, but since you asked you'll need everything..lol
I think you would have better luck buying used since you dont know or atleast sound like you know anything about it. Atleast start with a ood find and build to what you want.
good luck.
good luck.
i know what i need.
I need the chassis
Axels(MOA) will be nice to get though wont have to use a drive shaft
Motor
ESC
Receiver
Hubs
Shock Absorbers
Springs
Wheels
Tires
55T Motor
A Body
I just wanted to verify this and i will also like to know where i can get them (a website) i live outside of US
Any help will be appreciated
I need the chassis
Motor
ESC
Receiver
Hubs
Shock Absorbers
Springs
Wheels
Tires
55T Motor
A Body
To buy things individually will actually cost you more than buying a kit. In the other thread, you said your budget is 100-200 (dollars, I assume) which isn't much.
Stormer Hobbies has an RTR crawler that's decent for $249 (not including shipping) and they say they specialize in international shipping. I've done business with these guys alot.
https://www.ssl-stormerhobbies.com/c...=ns&pn=AX90011
TX
Can't go wrong with an AX10 now that they designed a comp regulations rig. Good for people to test the waters with too. The Venom Creeper is not a bad choice either to get your feet wet.
Once you know what you're doing the only 3 things left usually from the original build is your running gear, axles, and tranny lol.
CA
ORIGINAL: Ronaldo95163
i was thinking about going with the honcho
If your looking at getting an AX/SCX, look at the ARTR or kit, it is actually a better deal in the long run than the RTR which comes with some pretty crappy electronics... [:'(] As for the SCX, I think a 35>27 would be fine, its a "scale trail truck" so you will want some fun wheelspeed for it, but still going to have the torque you need for climbing [8D]
For the casual crawler type person, the Honcho is a hoot. 35T motor, 3S lipo. You can still use it for rock crawling, but it also has a respectable top speed; fun for bashing around in the yard.
ORIGINAL: calvino
It is based off the AX10 and from what ive seen in vids, its amazing. Knowing how good/tough my AX10 is
Since you got an AX10, what battery along with charger do you use?
i was also thinking about going with a 35t motor
