RCU Forums
-   RC Rock Crawlers (https://www.rcuniverse.com/forum/rc-rock-crawlers-277/)
-   -   Locking diffs (https://www.rcuniverse.com/forum/rc-rock-crawlers-277/1940026-locking-diffs.html)
mtrchamp 06-27-2004 04:49 PM
Locking diffs
How do you lock diffs?
Element 06-27-2004 05:48 PM
RE: Locking diffs
What kindof gearboxes are you using?
On my clod I used Office stick tack I didnt think it would work but its holding nicley;)
Wookie 06-27-2004 07:05 PM
RE: Locking diffs
There are lots of ways to lock a gear differential.
You can use:
JB Weld (my personal favorite)
Silly Putty (removable)
Epoxy
Solder
Welding
Super glue
Or just about anything else you can throw into a differential
If it's a ball differential:
Screws
JB Weld
Epoxy (not as good as JB Weld as it can shatter)
Basically all you need to do is fill it with one of the above and you are good to go.
mtrchamp 06-27-2004 07:37 PM
RE: Locking diffs
It's the stock rustler differential... if it's even a diff.... how do you lock it though, open the case and just put some JB weld in it?
CustomClod 06-28-2004 01:11 PM
RE: Locking diffs
I locked the diff on my rustler. All you have to do is take the diff out of the tranny and then open the diff up. Then you pour in the JB weld and put the diff back together. I turned my diff a few times to make sure the JB weld was mixed good. All you do after that is let it sit for a day to dry and then it is locked. Hope this helps.:D:D:D
Wookie 06-28-2004 03:49 PM
RE: Locking diffs
Make sure if there is oil or grease on the gears to clean them before using JB Weld. If you don't you risk the JB Weld not bonding to the gears or comming apart in the future.
mtrchamp 06-28-2004 04:27 PM
RE: Locking diffs
ok, then what? go with some T/e maxx a-arms and get another diff for the front?
Element 06-29-2004 11:58 AM
RE: Locking diffs
do emaxx arms fit the rusty?
If so why would you want to put them on theres no need for 2 shocks on each arm
whitexj 06-29-2004 12:56 PM
RE: Locking diffs
buy a spool and be done...
mtrchamp 06-29-2004 06:45 PM
RE: Locking diffs
what is a spool?
also, what motor sould I use and should I use a MG servo? I have an Orion 27Tx1 i can install... also what gearing? I used some nails to lock the diff
whitexj 06-30-2004 10:20 AM
RE: Locking diffs
i spool is basically a "welded diff" It is one piece and made of metal. Both of the wheels turn same direction at the same time no matter what.
mtrchamp 06-30-2004 03:45 PM
RE: Locking diffs
oh, I see... I locked mine w/ JB weld and Nails
