i want a rock crawler...tips. look
if i got this in the link below, what would i need to do, to get it to do what the truck in the second link video is doing
\ Thanks http://www.fdc.arizona.edu/drennen/s...ks&bitrate=384 http://www.fdc.arizona.edu/drennen/s...ks&bitrate=384 |
RE: i want a rock crawler...tips. look
Both links are the same, not sure what you're getting....
Well, the Ebay link is a bare chassis, so you wil need Clod gearboxes ($100-$150), shocks (between $20-$60), radio equipment ($150), ESC and motors ($100-$150), tires and wheels ($15-$60+ if you want the same ones on the rig in the video, they are out of production) and a body ($30). This is buying pretty much everything new, but you can surf Ebay an forums and I'm sure you can come across some screaming deals.
Yea mann.
Z4s are cheaper trucks. You should be able to pick one up off ebay for around 300 rtr. |
