Clod Buster and Bullhead
Whats the difference between the clod buster and the bullhead? Cause all i can see is that the body is different and maybe the color of some of the plastics. My neighboor has a bullhead and an old blazing blazer that im going to buy both for $100 so just wondering if its worth getting the bullhead to convert to crawler.
RE: Clod Buster and Bullhead
uh yeah....... I'll give you $50 for the Blazer[:-]
all i can see is that the body is different and maybe the color of some of the plastics. |
i thik bullhead axels are a bit smaller tho arent they? as in clod axels are wider so therefor need less adjustment?
uhh how about $500 but yeah thanks fo rthe info. ohh and what do you mean by needs less adjustment?
i was just guessing IF they are different. less adjustment meaning you with the bullhead if they are in fact skinnier then you would need wider wheel adapters.
The clod and bullhead axles are exactly the same. The differences between the clod and bullhead are: the chassis, shocks, end links, and axle bumpers are a different color. The suspension links (for lack of a better term), and wheels are chromed on the bullhead, while they are colored on the clod. The bullhead comes with a chassis stiffener while the clod didnt, but the super clod also now comes with it too. The only other difference (other than the body) is the front bumper which is different to go along with the new body.
i want a blazin blazer
