RCU Forums
-   RC Rock Crawlers (https://www.rcuniverse.com/forum/rc-rock-crawlers-277/)
-   -   Does this look ok???? (https://www.rcuniverse.com/forum/rc-rock-crawlers-277/5475154-does-look-ok.html)
Jatoff-roader 02-25-2007 09:48 PM
Too lazy to get a pic of the draft i did on paper.
Is this chassis look good??
http://i15.tinypic.com/44bysqo.jpg
3" gc 2.2"tires
4.5" on the front and rear plates
5" middles
Rc EnthuSiasTs 02-26-2007 09:47 PM
RE: Does this look ok????
looks a little top heavy, but looks like it has good ground clearance
R/C fan-addict 02-26-2007 09:50 PM
I'd say some shorter shocks to lower CG, maybe a bit longer top section on the chassis so that you can have a little longer area for the shocks. Also it looks as though you plan to mount the shock ends to the 4 links. This is generally harder to do than mounting it to the axle. You usually have to buy specialty links or design them yourself.
Anomie 02-27-2007 11:41 AM
That can be tough on a link not designed for shock mounts, but there are small clamps that are made to mount the shock to the link. They can be slid up and down the link for tuning, too. Check some out at the link below as an example.
[link=http://rc4wdstore.com/product_info.php?cPath=3&products_id=313]http://rc4wdstore.com/product_info.php?cPath=3&products_id=313[/link]
Jatoff-roader 02-28-2007 09:30 PM
no, there is a rod end mounted to the chasiis they will be used on that.
