Proline mashers
I bought a set of proline Mashers for my Scorpion. with a set of 2.2 mudrock beadlocks. First problem the mudrocks don't fit the Axial hexes. I resolved that problem with a small file and some time. Now I have one tire that keeps pulling out of the beadlock, always the same tire and the same area. my first thought was the wheel is bad but after taking it apart for the third time this afternoon I found the bead on the tire is actually very thin in that area as opposed to the rest of the tire. Any ideas for a solution to this problem? Please don't bash my tires selection they actually work very well for the conditions here in south jersey.
RE: Proline mashers
Go to your local hardware store and find a O ring that is close to the diameter (be careful that it isn't to thick of an O ring) you need.
Mount the tire to the wheel, then the O ring, and then tighten down the bead lock ring. |
| All times are GMT -8. The time now is 12:14 PM. |
