Go Back  RCU Forums > RC Boats > RC Sailboats
Reload this Page >
Volvo 70 line drawings?
RC Sailboats For all your r/c sailing needs, post here.
Old 05-21-2011, 04:14 AM
za.Nic
Default RE: Volvo 70 line drawings?
post edited: sorry missed Hew's filefactory link! thanks a ton for uploading! searched for a few solid hours to attain these !
Old 08-04-2011, 08:39 PM
kingplank
Here is my new 50" design, proven to be very fast
videos
http://youtu.be/c6Go6-LORow
http://youtu.be/_bQ44xIIzKo
http://youtu.be/ezonYspWGP0
http://youtu.be/7pB_3FxCmQo
http://youtu.be/XamVqgN1nbQ
Building plans
Old 08-07-2011, 03:06 PM
GLX
looked quite good actually - your own design ? Well done
it looks quite well balanced and able to to handle a bit of wind too. - what's the actual length of your boat ?
Old 08-07-2011, 04:37 PM
kingplank
Yes it is my own design, influenced by the latest VOR 70 and the Safran 60.
The chines are a little higher for more speed on upwind runs
50" (1250mm) weight 4.6kg
Ballast same as IOM
Rig: IOM "A or "B" ( in between as used)
or use Marblehead C rig
Old 08-08-2011, 01:45 PM
GLX
yes those chines looks good - even in IOM a lots of the newer design have these chines too and skippers who sail these boats claim it gives them more power after a tack and more drive upwind...
Old 08-23-2011, 03:14 AM
  #31
symont
Two questions:
1) The VOR70 from Vela seems to be design around acantingkeel. Does someone as a fixed keel design for this boat?
2) Does someone has these drawings in CAD instead of PDF? Or is there an way to transfer a PDF in CAD (Autocad, Corel Draw, Illustrator) accurately? I would like to draw the planking line on the shadows.
Thank youfor yor time
Old 09-10-2011, 07:39 PM
  #32
ruffled11
Hi,
I am wanting to build a vor 70 with my son. I would appreciate it if you couls send me the plans. my email is [email protected].
Many thanks
David
Old 09-14-2011, 11:01 AM
  #33
symont
OK, I now have an answer for both of my questions (see two post up).
1) Illustrator can open a PDF and see the vectorial info. No problem there then, at least on CS5. Good thing that they are both Adobe products! I don't know about Autocad and Corel, you will have to check.
2) Surfdabbler excellent "Volvo 70 Ericsson Build Log" thread seeded my initial confusion and... the solution. Since this built was all about a canting keel VOR70 (as the real one), I assumed that the drawings were made accordingly. But, on post #21, Surfdabbler explains his own confusion about this and conclude that the bulb and fin were designed for a fixed keel.
I guess now is the opportunity to give my thanks to him. This tread was my inspiration, my ticked into the hobby.
Old 12-14-2011, 07:05 AM
  #34
doods7
Hi,
Is it possible that some one sends me the pdf file pls ) [email protected]
Thanks.
Old 12-19-2011, 04:02 AM
  #35
symont
Hi Doods7,
See Hew's post #23. I took my PDF drawings thereand thelink is still valid.
Happy sailing.
Old 03-27-2012, 11:04 AM
  #36
max21
Hey can you send me a copy on the vovlo 70 plans
Email: [email protected]
Old 03-27-2012, 11:06 AM
  #37
max21
can you send me the plans of the volvo 70 please
Old 03-27-2012, 11:09 AM
  #38
max21
can u please send my the volvo 70 plans Email: [email protected]
Old 04-03-2013, 01:16 PM
  #39
timbokeen
Hi
Could you send me a copy of the volvo 70 plans
[email protected]
Old 01-31-2015, 02:45 PM
  #40
Lanky2
Could you please send me the plans for Volvo 70 [email protected] thanks
Old 04-20-2015, 07:07 AM
  #41
BIKERBOBW
Originally Posted by hew565
Plans sent. If anyone else wants the ones I have, I have uploaded them to a free file sharing website, filefactory.com. You can grab them all or just the one you want. ABN Amro I and II, Illbruck and Ericsson are there now. Here is the folder:
http://www.filefactory.com/f/6e01e30cc7e3300b/
Hew
I have tried the link but it appears to be broken; can you email copies of the ships listed above
email [email protected]
Old 05-07-2015, 06:05 AM
  #42
kingplank
Default VOR 65 Plans
Here are the plans of the latest Farr designed VOR 65
Adapted of RC
Capable of 6.8knots downwind, 3.8knots upwind (determined by GPS tracker)
No need for canting keel. Keep it simple; sail it well, and she will go fast
KP
[ATTACH]2094479[/IMG][ATTACH]2094480[/IMG][ATTACH]2094481[/IMG][ATTACH]2094482[/IMG][ATTACH]2094479[/IMG][ATTACH]2094480[/IMG][ATTACH]2094481[/IMG][ATTACH]2094482[/IMG]
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old 06-06-2015, 07:59 AM
  #43
blackfemmie
Hello Kingplank,
Can you give me some more information from the plans you posted from the latest Farr designed VOR 65. I am very interrested in wich scale the plans are. Maybe there is some more interresting information about this?"project". i am very interrested in these plans because i wanted to build the VO65. My VO70 (team Delta lloyd) is finished a couple years ago so i wanted to build the TEAN BRUNELL Vo65. In about 2 weeks they are here in the Netherlands(stop over at Scheveningen) so I have a good Photo-opertunity.
If would be very pleased if you can help me further.
Oscar
The Netherlands
Old 06-08-2015, 05:40 AM
  #44
kingplank
Oscar,
you can follow my many posts here, detail info of my Open type boats built
http://www.rcsailing.net/forum1/show...IMOCA-60-Macif
http://www.rcsailing.net/forum1/show...Safran-Open-60
http://www.rcsailing.net/forum1/show...-rough-weather
http://www.rcsailing.net/forum1/show...nd-rough-water
http://www.rcsailing.net/forum1/show...e-planing-hull
Old 02-04-2017, 02:39 AM
  #45
smitpub
Hello,
I know this is an old thread but I really want to build this Volvo 70 design and are hoping that someone would be kind enough to emai me a copy of the plans to smitpub at gmail.com
I have tried many times to email the designer and he no longer replies.
Steve
Old 05-02-2017, 06:14 PM
  #46
Laurd11
Originally Posted by smitpub
Hello,
Steve
Hi, I'm just arriving on this thread too. Smitpub, did you get the plans? If so, would you let me know where to find them? I only have a partial copy, and would be very grateful. Thanks!
Old 05-04-2017, 03:17 AM
  #47
smitpub
Unfortunately I have not received any replies to my post ... I am still keen to build the boat and are still looking for a copy of the plans .....
Old 08-05-2018, 06:57 AM
  #48
matrix270
Good day,
Please will you be so kind and send me the line drawings for the Volvo 70 ABN AMRO 1. I have been searching for years and found this website, I hope that you can help. I have sent numerous requests to the listed site with no reply.
Many thanks,
Andre
South Africa
Old 02-27-2020, 04:29 AM
  #49
JohnWay22
It looks good. Mayv=be in my childhood, my father has the dame Volvo
Old 04-29-2020, 01:23 AM
  #50
Tinoflying15
Default Volvo ocean sailboat plans
Hello everybody
I am trying to build my own rc sailboat but I cannot find any plans supplier through internet
Could anyone kindly send me the plans to my email [email protected]?
I would really appreciate it
