Go Back  RCU Forums > RC Boats > RC Sailboats
Reload this Page >
hi i have a 1960s boat hull
RC Sailboats For all your r/c sailing needs, post here.
Old 10-20-2008, 12:40 PM
ormer
Default hi i have a 1960s boat hull
a mast that is broken it is a tapperd wooden one and need to find a new one is there any ideas on what to use i also need sails
i can get sails made but a mast is a bit harder to locate
any ideas
thanks phill
Old 10-20-2008, 12:55 PM
Guiri
Default RE: hi i have a 1960s boat hull
If it has to be wood, it's almost cetainly needs to be hand made, probably from spruce or similar. If carbon is OK, you might be able to find a fishing rod blank of a suitable taper. Otherwise a non-tapered aluminium or carbon mast would be the choice. What size is the hull?
Old 10-20-2008, 05:55 PM
ormer
hi the hull is 48"long 14" wide
it is set out to look like a motor cruising yacht with a big cabin and open back
Old 10-20-2008, 08:30 PM
DONS BOAT WORKS
DONS BOAT WORKS's Avatar
We want pictures.
I use aluminium and carbon fiber arrow shafts for the mast.
Old 10-20-2008, 10:00 PM
Guiri
Go for carbon tube 8-10 mm outside diameter. Somewhat smaller for the booms. Kite shops are a good source as well as havigng ripstop for the sails.
Old 10-21-2008, 04:12 AM
mfr02
The original would have been dowel, as found in most timber shops. Diameter to suit the original base, taper by planing/sanding. pick a straight piece. Stain/varnish to taste.
Old 10-26-2008, 03:32 PM
GLMS
I have some older AJ Fisher sails that are new, The size of the boat would be a huge help and I can see if a set will fit. I also have some vintage masts that may work, let me know. John B
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
