RCU Forums
-   RC Sailboats (https://www.rcuniverse.com/forum/rc-sailboats-89/)
-   -   MODIFYING a SERVO TO HAVE MORE MOVEMENT (https://www.rcuniverse.com/forum/rc-sailboats-89/2987332-modifying-servo-have-more-movement.html)
Terryone 05-18-2005 12:29 PM
Hi,
Does any one know what has to be done to a standard Futaba Servo 148 to give it more movement to use as a sail servo.?
schmism 05-18-2005 02:15 PM
RE: MODIFYING a SERVO TO HAVE MORE MOVEMENT
your talking about [link=http://www.servocity.com/html/s148_standard_precision.html]this servo?[/link]
if so what size boat are you putting it on?
Terryone 05-18-2005 04:15 PM
Hi Schmism,
Its 40" long is a Germany Optimist ?
Dazzler_BE 05-19-2005 02:30 AM
Is far as I remember, it think it can be modified by removing/adjusting the potentiometer inside the servo BUT! I'm pretty sure that this servo does not have the strength to pull the sails on a 40" yacht. You're talking about a standard, 13-in-a-dozen cheap servo that comes standard in the box when you buy a new transmitter. There good for 1/10 scale cars, and small planes (trainers etc) and eventually as rudder servo in smaller boats. Anything else is way more than they can handle....
It might work at first sight, until you're actually sailing and there's a gust of wind, it could actually rip all the gears inside (remember, the standard 148 futaba servo is all plastic gears!)
Terryone 05-19-2005 03:19 AM
Dazzler BE,
Yes I have since realised that the 148 will not be big enough so I have now gone to a 1/4 Scale Servo
which is way above what I need.
I have infact now been given the proceedure for the modification, so its just a case of doing it now.
Thanks for your help !
schmism 05-19-2005 11:13 AM
i didnt want to post that, that servo wasnt going to work so dont bother trying to modify it till i new what size boat you were putting it on... but you know that now :D
Terryone 05-19-2005 11:31 AM
schmism,
I have already modified it as I want a 148 for single flaps on my Sunderland I'm building.
which needed more movement, so that all worked out OK
