fourtune 612 II
I've been looking at the seawind but its out of my price range. so now I'm looking at fortune 612 II is that just as good as the seawind also can you buy a replacement hull for it I've only found it for the first one thanks. please answer :)
RE: fourtune 612 II
If you are looking at a smaller boat, then I would advise you to get a Victoria, a Thunder Tiger boat.
It's a quick build, and sails very well. Good value too. Plenty of info out on the web, look here for upgrades; http://www.myrc.org/Library/Library....ilboatBuilding and here; http://www.victoriarc.org/index.html also; http://www.okanaganmodelsailboat.org/Index1.html |
RE: fourtune 612 II
so is the fortune 612 II good
RE: fourtune 612 II
also can you get a replacement hull for it
RE: fourtune 612 II
Why do you want a REPLACEMENT HULL?
If you put yours onto the rocks, then you fix it, just like they do on big boats. |
RE: fourtune 612 II
because I just want to have a backup one
RE: fourtune 612 II
Believe me, unless you drop your boat from a great height, stand on it or run over it with the car you wont need a replacement hull
RE: fourtune 612 II
ORIGINAL: boatfisher25 because I just want to have a backup one Larry L. |
