Reload this Page >
How to build dummy ww1 1/3 spandau guns
Old 10-16-2011, 04:49 PM
valleyk
Default How to build dummy ww1 1/3 spandau guns
I'm past my spending limit and need to build 1/3 scale guns. Any advice on an easy approach to building a spandau machine gun. Maybe someone has a build forum Icould be directed too?
Old 10-16-2011, 05:51 PM
abufletcher
abufletcher's Avatar
Default RE: How to build dummy ww1 1/3 spandau guns
Well, let's see, a pair of 1/3 scale Spandau kits from BUSA would run about $60 plus shipping. So that's the price to beat. Luckily it shouldn't take more than some scrap wood and maybe some aluminum sheeting to make a respectable set of guns.
http://shop.balsausa.com/product_p/g904.htm
With good reference drawings blown up to 1/3 scale you shouldn't have much problem making the receiver parts or the barrel. The tricky bit is the slotted cooling jacket. Unless you were going to get this part laser cut (involving both time and money) the best bet might be to make it from lithoplate/aluminum sheeting. I've done this on a much smaller scale with a scratch-build Madsen machine gun but some variation on this theme should work for the 1/3 scale Spandau. The key is finding/making a tool to cut the slots.
ID:	1675299   Click image for larger version
ID:	1675300   Click image for larger version
ID:	1675301   Click image for larger version
Old 10-17-2011, 06:21 AM
LesUyeda
Banned
"The key is finding/making a tool to cut the slots. "
For 1/3 scale, how about using manila folder stock for the sleeve; brass tubing sharpened and shaped into an oval for the punch. Then dampen, and roll.
Les
Old 10-17-2011, 08:33 AM
Teus
Teus's Avatar
ORIGINAL: LesUyeda
''The key is finding/making a tool to cut the slots. ''
Or find a small company that can CNC it for you
For our project (5 1/3th scale D-VII's) we are also making our own Spandau's. The CNC aluminum plates did cost us about $7,00 each incl. material. I can't make it for that money. I have 10 barrels ready now and now we only have to make a mould for the housing.
ID:	1675519   Click image for larger version
ID:	1675520   Click image for larger version
ID:	1675521   Click image for larger version
ID:	1675522   Click image for larger version
ID:	1675523   Click image for larger version
Old 10-17-2011, 08:40 AM
abufletcher
It doesn't get more perfect than THAT!
Old 10-17-2011, 12:57 PM
TKFOKKER
Sure would love to have a set of those for my GTM D-7!!!!!!!
TK
Old 10-17-2011, 02:58 PM
Lucky Dog
Lucky Dog's Avatar
ORIGINAL: LesUyeda
Les
That should work fine. The way I've done it (for 1/5 scale) is to use a punch on both ends of the slot then use an Exacto knife to finish the slots. Otherwise, just like you say. Very thin lite ply would maybe work better on 1/3 scale. That's what the laser cut AZM barrels are made from on their 1/3 gun kit, but card stock is used on the 1/5 scale.
Old 10-17-2011, 04:31 PM
N1EDM
Maybe I could put one of those on the cowl of my Cub???
Bob
Old 10-17-2011, 05:39 PM
valleyk
I think im going to bite the bullet and buy balsa usa guns. Has anyone had experience with these balsa usa  gun kits?
Old 10-18-2011, 04:38 AM
Lucky Dog
Lucky Dog's Avatar
I can speak for their Spandau kit, but I've built their Lewis Gun in 1/3 scale. It was nicely done, just very basic, not much detail.
You might also consider Arizona Model Aircrafters Spandau kits ($59.00/pair). While not totally accurate, there's a nice amount of detail, and they (at least used to) come with leather MG belt and brass shells. You can view the instructions on his web site. That being said, a word to the wise, if you decide the AZM route, make sure they are in stock before you order, or you might wait a long time to get them.
Old 10-18-2011, 04:46 AM
abufletcher
The challenge is (always) how to make wood look like metal. Seems like no matter how many coats of primer you use, wood always looks like wood. []
Old 10-18-2011, 06:35 AM
WinterHawke
WinterHawke's Avatar
ORIGINAL: valleyk
I know that Del Johnson used the Balsa USA guns on his GMT 1/3 Fokker Dr.I, and showed the results on his build thread here:
http://www.rcuniverse.com/forum/m_43...29/key_/tm.htm
and continues through about page 33.
Seems his biggest issue with them is that they are very labor intensive to get sealed, but with the effort they do turn out nice.
Best regards,
Lee McD
Old 10-18-2011, 06:41 AM
LesUyeda
Banned
As far as AZM, try this.
"http://www.rcuniverse.com/forum/m_7714698/anchors_7714698/mpage_1/key_Arizona%252CModels/anchor/tm.htm#7714698"
Unless things have taken a 180 turn.
Les
Old 10-18-2011, 08:16 AM
CaptainHook
My Feedback: (80)
CaptainHook's Avatar
Scratch building is the best route to take. Yes, they are labor intensive but the result will be much nicer than any other kit on the market. These are what I put in my 1/3 Fokker and took about 80 hours.
ID:	1675918   Click image for larger version
ID:	1675919   Click image for larger version
Old 10-18-2011, 01:51 PM
abufletcher
Beautiful work! Not many modelers have that kind of patience (or skill). How did you make the cooling jacket?
Old 10-18-2011, 03:37 PM
CaptainHook
My Feedback: (80)
Thanks, Abu. The cooling shrouds are made of .020 styrene plastic, capped at both ends using 1 1/4 brass faucet pipe. I had to drill all holes in the styrene, then painfully cut from hole to hole to form the slot. Faucet pipe slots were milled. The receiver housing is balsa construction similar to the BUSA and then covered in styrene so there is no major filling before prime. Most other parts were made from a thicker styrene. The ends of the barrels are made from CA tips and, believe it or not the cap on a Vicks nasal inhailer (cut the top of the cap off). They are holding up very well after 4 flights and I have not had any problems with them falling apart.
ID:	1676217   Click image for larger version
ID:	1676218   Click image for larger version
ID:	1676219   Click image for larger version
ID:	1676220   Click image for larger version
ID:	1676221   Click image for larger version
Old 10-20-2011, 09:46 AM
frets24
My Feedback: (15)
frets24's Avatar
ORIGINAL: CaptainHook
That's the beauty of this hobby. Seeing the result of craftsmen using the mundane everyday objects to recreate in small scale the items of necessity for our planes. Ecellent work there C'hook!!
Old 10-27-2011, 11:15 AM
TKFOKKER
Will anyone ever step up to the plate and manufacture a GOOD set of third scale guns. Now that would be nice, and sure make it a little easier on us German aircraft builders. I'm hoping GTM will some day do this. But for now we are stuck with making our own or modifing Balsa USA, or AZM take your pick. A year ago Glenn, of GTM was getting his prototype 1/3 rd scale D-7 ready for Top Gun Team Scale entry for which I was the pilot. Glenn had no guns on the plane and not enough time to build a pair so I stepped up to the plate and made a set starting with Balsa USA's kits. Here is the build of those guns, along with the changes and added details to get them to a rather respectable gun used on a Top Gun Plane. By the way we ended up taking first in team scale, a first for WW-1 aircraft.
TK
ID:	1679401   Click image for larger version
ID:	1679402   Click image for larger version
ID:	1679403   Click image for larger version
ID:	1679404   Click image for larger version
ID:	1679405   Click image for larger version
ID:	1679406   Click image for larger version
ID:	1679407   Click image for larger version
ID:	1679409   Click image for larger version
ID:	1679410   Click image for larger version
ID:	1679411   Click image for larger version
Old 10-27-2011, 11:20 AM
TKFOKKER
More pic's of the B.USA Guns
TK
ID:	1679413   Click image for larger version
ID:	1679414   Click image for larger version
ID:	1679415   Click image for larger version
ID:	1679416   Click image for larger version
ID:	1679417   Click image for larger version
ID:	1679418   Click image for larger version
ID:	1679419   Click image for larger version
ID:	1679421   Click image for larger version
ID:	1679422   Click image for larger version
ID:	1679423   Click image for larger version
Old 10-27-2011, 11:26 AM
TKFOKKER
Again more pic's
TK
ID:	1679425   Click image for larger version
ID:	1679426   Click image for larger version
ID:	1679427   Click image for larger version
ID:	1679428   Click image for larger version
ID:	1679429   Click image for larger version
ID:	1679430   Click image for larger version
ID:	1679431   Click image for larger version
ID:	1679433   Click image for larger version
ID:	1679434   Click image for larger version
ID:	1679435   Click image for larger version
Old 10-27-2011, 11:33 AM
TKFOKKER
And the end result.
Thanks for looking.
TK
ID:	1679443   Click image for larger version
ID:	1679444   Click image for larger version
ID:	1679445   Click image for larger version
ID:	1679446   Click image for larger version
ID:	1679447   Click image for larger version
ID:	1679448   Click image for larger version
ID:	1679449   Click image for larger version
ID:	1679451   Click image for larger version
ID:	1679452   Click image for larger version
ID:	1679453   Click image for larger version
Old 10-27-2011, 02:28 PM
abufletcher
Once again we have proof that the solution to the question of "where can I get scale X" is BUILD (OR MODIFY) IT YOURSELF! Outstanding work! And, besides, it's there so much more satisfaction in building something like this yourself? I believe the "behavioral economists" refer to this phenomenon as the IKEA effect.
Old 10-27-2011, 02:55 PM
Highflyer2
Highflyer2's Avatar
Great work Tom. I'm just starting a set of guns for my Albatros. I will use your pics as a guide. Now if I could only machine all those bits half as good as you did!
John
Old 10-27-2011, 03:16 PM
TKFOKKER
Hi John
I was wondering how that Albi was doing. Must be close to finishing. Would love to see some pic's.
TK
Old 10-27-2011, 05:40 PM
Highflyer2
Highflyer2's Avatar
here's a couple of pics Tom. She is a great flyer:
ID:	1679577   Click image for larger version
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
