Reload this Page >
1/7 AT-6D Harvard / Texan
Old 11-01-2014, 04:35 PM
Sir Blue Henry
Default 1/7 AT-6D Harvard / Texan
I bought a fibreglassed fuselage / foam winged Harvard a while back and was instantly upset with how non - scale it was. Decided to improve it, and in the ned realised I might as well be doing one from scratch. Started researching year back but stalled. I want to get this going now.
The main intention is to produce a good quality fuselage in Fibreglass including moulds. Wings are not a priority. I will work on that if the fuselage turns out ok.
Old 11-08-2014, 04:16 PM
Sir Blue Henry
Centreboard is done. Now busy on Wing Centre section Upper surface design.
Old 11-15-2014, 11:59 AM
Sir Blue Henry
A lot of planning and analysis of Centresection upper surface as well as finding my original NACA2215 drawing as obtained on the net was not as accurate as I had believed , and after finding a Vector drawing NACA2215 far better, I am now confident with the profile as applied to Centre section and where this fits to the fuselage.
Starting on jig / plug for Centre section upper surface
Old 11-22-2014, 12:33 AM
Sir Blue Henry
ID:	2049251   Click image for larger version
ID:	2049252   Click image for larger version
ID:	2049253   Click image for larger version
ID:	2049254   Click image for larger version
ID:	2049255   Click image for larger version
ID:	2049256   Click image for larger version
ID:	2049257   Click image for larger version
Old 12-05-2014, 06:45 PM
Sir Blue Henry
Centresection framework jig is coming on. Not too long and I can start pressing hundreds of rivets into my sheetmetal upper surface.
Old 12-22-2014, 02:30 PM
Sir Blue Henry
Have ordered a set of blueprints for the Texan. Hope its a goos and usable set from which to create cross sections and bulkheads.
Old 12-22-2014, 02:38 PM
Sir Blue Henry
Have been doing a number of fibreglass trials to test various layers and thicknesses. That has gone pretty well.
Then decided to try my first mould - of a small boat - first attempt was a failure - but a lesson worth learning anyway.
Next trial on the boat moulding will be in tghe next week or so, with at least 2 parting boards
Old 12-22-2014, 02:41 PM
Sir Blue Henry
Analysis of wing join plate and angle of incidence has been Ok.
Work in Corel draw on the Centresection upper surface has also been going fairly well - but without blueprints, the positions of rivet lines are a bit off.
ID:	2057046   Click image for larger version
ID:	2057051   Click image for larger version
Old 12-22-2014, 03:05 PM
Sir Blue Henry
Old 12-22-2014, 03:29 PM
Sir Blue Henry
ID:	2057065   Click image for larger version
ID:	2057066   Click image for larger version
ID:	2057067   Click image for larger version
Old 12-27-2014, 02:23 PM
Billy J
Billy J's Avatar
Default Billy
beautiful work !!! Looks like u been around full scale planes
Old 12-27-2014, 04:47 PM
Sir Blue Henry
Yes, and I was lucky enough to do miltary training on harvards. Just love the aircraft. This will be a slow project but hopefully well worthwhile
Old 12-28-2014, 12:52 AM
Sir Blue Henry
progress on next round of trying to make the boat hull, which is of course just preparation for being able to do the Texan. I dont want to stuff up when it matters, so Im just doing a lot of smaller practice exercises with fibreglass and resin.
Next I need to seal and polish - lots of prep - sigh
Old 01-01-2015, 07:02 PM
Sir Blue Henry
more progress on boat hull, so far so good although various aspects have been a learning curve.
Name:	20141230_110641 (Large).jpg
ID:	2059686   Click image for larger version
Name:	20141230_133344 (Large).jpg
ID:	2059687   Click image for larger version
Name:	20141230_161355 (Large).jpg
ID:	2059688   Click image for larger version
Name:	20141231_100843 (Large).jpg
Old 01-04-2015, 02:34 PM
Sir Blue Henry
Name:	IMG-20150103-WA0004 (Large).jpeg
Old 01-04-2015, 02:35 PM
Sir Blue Henry
ok - well that seems to have been successful. need to just make the rear part and then I can start moulding boats, but of course need to get back to the main issue, so will soon start on various bits for the Harvard
Old 01-10-2015, 10:55 AM
Sir Blue Henry
Produced my first boat from the moulds and it worked out pretty well. The learning curve is very worthwhile in preparation for making the Harvard parts and just getting skill with Fiberglassing.
I need to get a proper paste to use for the parting boards, and also PVA for separation. The wax works but it still takes major effort to coax the part out of the moulds, even with soft taps with rubber mallet.
Old 01-10-2015, 10:59 AM
Sir Blue Henry
With the large amount of work going into this model, my original thoughts of doing a 1/7 and then a 1/3 come into question more and more. Wonder if I should do a 1/5 rather than 1/3?
or if the effort is worth it. As it is, even considering selling a few fuselages to make back some of the funds invested, would be a time consuming thing as making parts from the moulds is not the quickest thing to do, and also, this Harvard will have so many parts, not just a simple fuselage and 1 or two parts.
Old 10-23-2015, 04:15 PM
Sir Blue Henry
OK - time to get back to work on the Centre section upper surface and jig etc.
Old 10-25-2015, 11:09 PM
Sir Blue Henry
Busy with last bits of detail on the Corel drawings of the upper surface. then to print out in reverse and lay against the metal sheet, which will then go onto the jig
Old 10-26-2015, 01:15 AM
Sir Blue Henry
Old 11-04-2015, 11:06 PM
Sir Blue Henry
Decided to buy a set of Blueprints off ebay - lets see what I get. Good quality hopefully.
Old 12-18-2015, 03:59 PM
Sir Blue Henry
Finally my CD of blueprints has arrived. Delayed by customs inspections! A quick inspection shows medium to good quality. Lets see if I can find the drawings I require amongst the 1600 images
Old 12-19-2015, 12:37 AM
Sir Blue Henry
well there it is - my long awaited Harvard blueprints.
I have been through a few hundred files so far and the quality seems consistently ok to good.
Found some very good stuff so far which will help me a lot.
maybe every 15th to 20th image is a major drawing, with the rest being minor detail drawings which will not be relevant.
So finally the project can go ahead.
Name:	20151219_122729 (Large).jpg
Old 12-22-2015, 01:34 AM
Sir Blue Henry
NAA badge as on the main 3 view blueprint
