Walt Musciano 67" Navion plan RCM-878 Information
Has anyone here built the Walt Musciano 67" wingspan Navion RCM-878? If so did you build it with retracts? I'm looking into having a short kit cut and modifying the design for retracts. I have located the cowl and the canopy. What I would like to know is if there are any modified versions of this plan and any critiques those who have used these plans to build with in the past.
This Navion is a good looking, good flying model. It was designed well before retracts came into common usage. I'd be surprised if there were plans available, showing retract installation.
Hostetler has plans for a larger version. Retract installation is designed into the air frame. Wendell Hostetler Pawnee
The plans are easy to find they are on the AeroFred and Outerzone sites both along with the construction article from RCM. I have two laser cutters both offering estimates on cutting short kits. The amazing part is Fiberglass Specialties has the cowl and canopy available.
I can see where you might adapt a similar sized cowling but it is pretty neat that you can get a canopy. In looking at the plans it looks like the main gear was originally designed to be mounted on to plates. Ordinarily I would look at that as an outdated method but in this case the plates might be slotted to accept a set of gear mounts. Something from eflite might be made to work. The nose gear might take more work as it looks like wheel would protrude into the bulkhead "D" and interfere with the front wing mount. You might be able to mount the nose gear father forward to get clearance..
