MQ9Reaper assistance
A friend wanted to build an MQ9 and I assit with construction and moulding experience.
It will have 4m span, electrical retracts , free running front wheel and steered by 2 electromagnetic brakes on the main wheels. Rotating angles should be scale. Fuselage will be 2m long and fibreglass, wings and elevators is wood construction. We will take over a propulsion from variant projects(bulls eye and avion rapide) with slightly enlargement 17x12 leading to scale prop size together with 5000 4s a second and third accu in the centre of gravity for long endurance. The aircraft will be equiped with flight control and some special avionic. Kinematic for retracts is predeveloped and has to be updated when the mechanic parts are fix. Main issue at present ist the 120 degree rotation of front wheel and a new way to establish mastermould by 3d printing. Cheers Matzito
