BUSA Fokker DVII
#306
Yep, you were right about the 2.20. It flew the plane at a good scale speed at 2/3 throttle. Take off was VERY short, and thanks for the warnings about needing a lot of down trim. I put a bit in before the flight, and was ready to add a bunch more. By the time I made my first lap, it was flying hands off. It sure looks good in the air. All smiles here. There is a chance that at the field on Tuesday, there will be 2 DVII's and 2 Tri-planes. All Balsa USA and all 1/4 scale. should be a good photo op! Thanks for all the help everyone.
#308
I just bought one of these BUSA 1/4 DVII's used for $375. As far as I know it has never flown but the engine has been ran. It has an OS 3500 swinging a 20x10 APC prop.
I have read through the entire thread and will check on all the stuff mentioned so far such as CG and incidences.
What can you tell me about the flying characteristics of the 1/4 D VII.
I hope someone will see this post , being that it is a little old. I'm about to finish my BUSA Fokker D7 also. I've built it around a Zenoah G38, which seems to be the engine of choice. My plane is about 20 lbs, BUT this plane is MASSIVE! The same engine could not haul my Spad XIII. I've talked w/ a bunch of D7 owners and they have a lot of success using the G38. My question is performance. My engine is relatively new and using a 20X6 prop can barely hit 6,200 RPM!!! Most of the guys I talked to are using a 20X8 prop, but are not sure of the RPM rating. Can anyone out there (w/ success flying their D7) tell me the prop size AND RPM of their G38!? I also understand that the OLDER version of this engine can hit higher RPM's. (older version being the one w/ the metal prop shaft w/o a choke). Any truth to this?
Ray.
Ray.
#311
I am using a 19-8 Xoar. I cannot tell you the RPM, but this size really woke up performance over the 20-6 props I was using. I think the Zenoahs like to turn up the RPM. I bet an 18" prop would be a good choice as well. To be honest, I would not put a G38 in another DVII. I feel mine is underpowered.
#313
I fly my BUSA D-VII with a G-38 and a ZDZ 20 x 8 prop. I do not know the RPM of my motor, it is one of the older ones. The plane flies all day at 1/2 throttle. I think the prop of choice for the newer G-38 is an 18 x 8. The G-38 is the right engine for this airplane.
Wild Bill
Wild Bill
#314
This is an old thread, but I have something exciting possibly for anyone interested in this plane. I just placed an order with a company that is going to 3D print the radiator mesh for me. I just ordered a 3/8" sheet, that I can use to replace the wire mesh in my cowl. This will have the scale sized hexagon pattern. I am having it drafted out of black material, making it easier to paint and maintain a good color.
The price was extremely reasonable. As soon as I get these parts, I will post my progress and provide info on how to obtain this material. The 3D printing is a great solution to many of our scale detail needs. This has been an item I have needed for years to really finish off my Fokker.
#317
Vertical,
I have a similar setup on my D7. GTM full cockpit, done with GTM Lozenge fabric. I don't like to reinvent the wheel....I noticed that in one of your posts the your pilot was "removable". I was trying to do the same with mine. The cockpit is so fragile that I don't think I could attach the pilot to the seat. I was thinking of a platform that adjusts to grab the inside frame. How did you do yours?
Ray.
Ray.
#318
Vertical,
Ray.
Ray.
What I did was epoxy a short section of music wire into the upper longerons on the left and right side of the fuselage. I mounted my pilot to a plywood plate. after fitting the plywood plate for length inside the fuselage, I drilled small hole in the ends of the plywood to slide up, and into the music wire. I used very small ( 1/2A) glow fuel tubing to slide up the music wire, and keep the plate/pilot in place. I have had no issues with this arrangement.
Funny, I was just in my shop mounting my Best pilots Lothar pilot in my newer DR1 tripe. While we all want full body pilots, this one is very hard to mount, and I am not even using the legs as he just does not fit in there. I think the 1/4 scale aces of Iron pilots are way too small, and serious modifications would have to be made to get a full sized Lothar into my DVII. I would have to lose almost all of my interior cockpit detail, as I did with my Triplane.
Which pilot are you using?
#320
Vertical,
Thanks for responding. I'm going to use the Aces of Iron, Blue Max. I looked at the "Luther" Best pilot and I'm glade I didn't order it. My D7 came in at 20lbs, which isn't bad till I had to add 5lbs to balance! I don't remember ever building a tail heaven plane this bad! I think the full size pilot would have really caused me serious CG problems. The plane flies great the only problem is that the wing strut solder joints tend to break after flight. I do fly it slow, but also do many different maneuvers. I tried "stay bright" solder and it seems to hold up better.
Ray
Ray
#321
I posted a Picture of this on another thread here at RCU. But just in case some missed it. I put the radiator from Iflytailies into one of my DVII's. I did it fast, and on the next one I will take my time to make all the ends line up better. But for the price of two 5 inch sections, it really helps the front end on the Balsa USA DVII. Well done Iflytailies!
#322
Funny, I am the one that asked for the stuff, and I still have not done mine yet. I have her on the bench though and getting ready to do it. I ordered a fine tooth bandsaw blade to cut it. Waiting for that.
Looks good! Certainly better than screen material. I guess we will find out how good the cooling is?
#325
It took two pieces of 5 x 2.5 inch. yes, the parts are flat. The parts are trimmed to fit.The cost of each was just under $10. and delivered to my door in 2 days, total was around $27. I really don't think the cooling is going to be a problem. The holes are big enough and as you can see, the blue push rod tubes of my motor are easy to see. The area of concern to me is how it will hold up to the heat of the motor. flying should be ok, but how about after the flight sitting on the ground when no air is passing thru it and the motor is still hot. Time will tell. I think this would be a great thing to have during the build, and not have to retro fit it. Then the installation would be cleaner. It's very hard for me to have to carve into a perfectly good cowl.
