Reload this Page >
Home Made Decals
Home Made Decals
Old 08-05-2002, 05:49 PM
JET FX
JET FX's Avatar
Default Home Made Decals
Has anybody tried using home made decals? If so what/ how???
I just got a quote from one of the decal manufactures and nearly fell over at the cost...
I figure if I can find decals from a plastic kit, scan them into my computer, then enlarge to size I need then print onto decal paper, this could work???
Apart from possible low pixel image quality this should work...
So where can I find A4 size decal paper for my printer?
Old 08-06-2002, 02:46 AM
rcalfred
Default Decals--Again
www.micromark.com. Has water slide paper for both laser jet and ink jet printers. Used it for the decals on my Lockheed Vega Winnie Mae. Worked great. After applying I clear coated them using clear Polytone paint. Regards.
Old 08-06-2002, 03:52 AM
JET FX
JET FX's Avatar
Default decals
Thanks Al, do you know if decal paper is only obtainable through similar companies to the one you suggest or is there a more readily available source eg office supply stores etc. Any pics of your Winnie May, I would love to see how these decals turned out...
Cheers-
Old 08-06-2002, 07:14 PM
F86_SABRE
Default DECAL MAKING
Marty,
Try going to the small scale plastic models as they usually have some good write-ups on how to make decals.
Try this website. I have seen some write-ups on the subject there
http://www.clubhyper.com/referenc.htm
Browse there...some good information in there besides decal making.
Regards
Reuben Saliba
Malta
Old 08-06-2002, 08:19 PM
dant-RCU
dant-RCU's Avatar
Default more decals
If you do a search on "homemade decals" you will get a couple of threads that will fully answer your questions.
The search engine is a nice feature
Dan
Old 08-06-2002, 08:22 PM
F86_SABRE
Default DECALS
Marty,
Click here:
http://clubhyper.com/reference/aungs...stomDecals.htm
Very informative article
regards
Reuben
Old 08-07-2002, 05:52 PM
Schwoop
Marty,
With laser copying and color inkjet technology out there today, you're nuts to spend money on someone elses decals when you can make your own (provided you have a pc and access to a color printer).
I started as a plastic model guy and began making decals a few years ago and have since "scaled up" the work for my RC warbirds. It does take a bit of time, but the results are well worth it!
I use a decal film (both clear and white backed - since 95% of printers won't print white) purchased at HobbyTown USA stores for plastic models.
Scan in your artwork and scale to appropriate size. Here's where your graphics skills are tested... To get a good print without jagged edges, blur, or any other nasty effects, you have to make sure of a few things:
1) Make sure you scanned your artwork and save it at a high resolution: at least 300 dpi (dots per inch) otherwise it will always produce terrible results on the printer.
2) You may have to do some touchup work, if not redraw the entire image, using your scanned copy as a tracing image. This is where the time comes in.
3) Use a fixative immediately after the print comes off the press. You can use Testors Gloss Clear spray paint - 3 full coats, no less. Otherwise the toner and fuser or ink will crack off.
Then apply it like other water adhered decals. Finally coat the entire plane's finish with a fuel proof fixative.
I'm building a Sureflite Me-109 with the markings of Adolf Galland -can't find decals like his (mickey mouse under cockpit) anywhere on the market!
Hope this helps,
Craig
Old 08-07-2002, 06:36 PM
F86_SABRE
Default DECALS
Craig,
See if this is what you are after?
Reuben Saliba
Malta (Europe)
Old 08-08-2002, 10:28 PM
Schwoop
That's it!
Did you redraw this-?-it looks a bit different from the one I'm using--but still awesome!!!
Old 08-08-2002, 10:36 PM
heavy date-RCU
Do a search for Tango Papa decals. His are done on an ALPs printer. They are as good as you can get and look like paint.
I have all the gear to do my own now. I got an ALPS printer and Corel Draw. The decal paper I get from Tango Papa as it is never older than 2 months. Makes a big difference.
To really make good decals I suggest you check out the how to page at Tango Papa's site. It is very well done and pretty easy to do.
Once you make your own, there is no limit to what can be done. It is great to be able to mark a model and know that no one else has the same markings.
Hans
Old 08-09-2002, 01:31 PM
GarySS
My Feedback: (13)
Default Fuel proofing decals
Hey Schwoop, and anyone else: I made some decals using Micromark products and a commercial laser printer. Then I fuel proofed them by spraying Lusterkote clear and a Coverite clear. Both have yellowed some over time. (No problem with fuel,tho).
Does the Testor's fuel proofer stay truly clear? I would like to bet back to making some more decals without the yellow tint!!!
Old 08-09-2002, 02:52 PM
JET FX
JET FX's Avatar
Default DECALS
Hi guys, thanks for the input so far, lots of great info here! I have just bought some 'Experts Choice' white decal film, its made by Bare-Metal Foil. I plan on trying for the first time to print out my own decals for my 1/5 scale MIG15. I have scanned a set of Tamiya 1/48 scale MIG 15 decals at 300dpi, I will resize and play with the colour using Adobe photoshop.... I have been recommended to use 'Future' furniture polish brushed on to the newly printed decals before application, anyone used this method???? my only concern is if the 'Future' (acrylic) polish will be compatible with polyurathane clear coat to seal model.
Old 08-09-2002, 05:01 PM
F86_SABRE
Default DECALS GERMAN SQD
Craig,
This one?
Reuben Saliba
Malta
Old 08-09-2002, 07:35 PM
F86_SABRE
Default DECALS - ME109
Craig,
or this
Reuben
Malta
Old 08-14-2002, 11:22 PM
heavy date-RCU
Default Decals
One other thing I should mention. You really need to use a program like Corel Draw for making decals. Photo shop and other photo programs are raster programs, which means the more you enlarge the decal, the worse it looks. Corel Draw is a vector based program so you can enlarge the decal and it will stay sharp.
As for printers, ALPS works the best and can print in white so you can use clear decal paper. Laser printers work O.K. but you are still working with ink and it can run all over before it dries. The ALPS uses a dry ink that is water proof so there is no running problem.
I am not sure if ALPS ink is fuelproof or not. I have never tried it without a clear coat over them.
Not trying to sound like a printer salesman, but thought you would like to know the best way to go about it.
You should really go to Tango Papa's web site as his instructions for making decals is great.
Hope this helps out a bit. Have fun making your own markings!
Hans
Old 08-15-2002, 02:32 AM
SCALECRAFT
My Feedback: (13)
SCALECRAFT's Avatar
Dear Sirs
For decal paper I would go to BELART.COM. Buy it in bulk and save a ton of money. Its probably where the hobby guys buy it from.
I made 1/7 scale BF 109 marking scanning pics from my books and modifiying them to my needs.
They off to KInkos for a laser copy.
Experiment for your own applications.
Steve
Old 08-15-2002, 02:40 AM
Merlin65
A cheaper alternative to CorelDraw is Xarax. A demo is available at http://www.xara.com/products/xarax/
This little vector program was used to make the attached marking for a Spitfire of 152 Hyderabad Black Panther Sqn RAF in SEAC markings.
While the Alps printer is the best option, it is expensive unless you are going to make hundreds of decals. A better option is to put your artwork on disk and get any printing house to make the decal. Alternatively you can make paint masks with any printer.
Military fonts for most air forces can be found at http://members.aol.com/p5219/fonts.htm
Merlin
Old 08-15-2002, 03:29 AM
JET FX
JET FX's Avatar
Default Great Info
Thanks guys! for all this great input, I was wondering if some of you maybe able to post some pics here of your finished models, complete with home made decals! I would really like to see how well these decals turn out when applied to the models! transparency and finish... : )
I may have been able to save myself weeks of airbrushing on my F16 tail, if I had the decal know how...
Cheers
Old 08-15-2002, 04:37 PM
DanSavage
DanSavage's Avatar
Default Re: Great Info
I usually use a combination of decals and cut vinyl. If I need a white background for the decals, I'll cut it out of vinyl, lay it down, then put the decal on over that.
F-106: Combination of decals and Stika cut vinyl.
Sukhoi SU-27 Flankers: Mostly inkjet decals and some Stika-cut vinyl.
General Dynamics WB-57N: Tail markings all inkjet decals.
A-4 Skyhawk: Combination of inkjet decals and Stika cut vinyl.
Old 08-15-2002, 04:58 PM
JET FX
JET FX's Avatar
Default DECAL pics
Dan, thanks for sharing pics of your models, they look great!
I gotta ask though whats a WB-57N? any more pics! : )
Old 08-15-2002, 05:17 PM
DanSavage
DanSavage's Avatar
Default Re: DECAL pics
Dan, thanks for sharing pics of your models, thay look great!
Thanks!
NASA's version of the USAF RB-57F.
http://www.jmrcflyers.com/gallery/b57.htm
Dan
Old 08-15-2002, 06:49 PM
JET FX
JET FX's Avatar
Default WB-57
Hey Dan that looks absolutly awesome! I would love to scale the WB-57 up somewhat, maybe double the size of yours and install a couple of MW54 turbines! What you think? Is this similar to the TH-1. Or the U-2 would make a great giant scale turbine project...
Old 08-15-2002, 07:03 PM
-JC-
My Feedback: (26)
-JC-'s Avatar
Default ALPS 500
I got an Alps MD5000 printer i'm not using. About 1 Year old and has been used twice. Don't remember what they sell for anymore, but $200 and it's yours.
Comes with about 8 print cartridges (about $10 each)
The best printer available for homemade decals
Old 08-15-2002, 07:30 PM
F86_SABRE
Default Decals
Hey Ozcan,
Will this one help?
Regards
reuben
Malta
Old 08-15-2002, 09:33 PM
JET FX
JET FX's Avatar
Default Tiger Tales
Hi Reuben,
I also have that image and used it as the bases for an enlarged stencil for the tail of my F16. I would definetly be trying to create it as a decal if I had to do again.... I had no building to do last winter : )
