Plans wanted
RE: Plans wanted
There is a flying scale rubber plan in the Aeromodeller range which you can access through www.modelflying.co.uk. You'll see the catalogue mentioned on one of the ads in the right side of the window. I know nothing about the plan, but it costs about £6.00, so it is probably quite big and could be converted to electric quite easily. RCMW do a CD of a photographic survey of a Messenger, but no plan.
Best of luck with your search.
Chris Rayner
Chris Rayner
RE: Plans wanted
Check out the third plan from the top on this page: [link=http://www.modelflyermagazine.com/Frames/Plans/Plans03.htm]R/C Model Flyer[/link]. I hjave seen the plans and if you are up to it the result will be a beautiful scale model of a very interesting subject.
RE: Plans wanted
ORIGINAL: Red B.
I sent them an email requesting an exception to ordering the plans, hopefully they will allow it.
RE: Plans wanted
ORIGINAL: Chris_Rayner
Chris Rayner
Chris Rayner
AB, CANADA
RE: Plans wanted
There is a Miles Messenger plan available from www.modelflyermagazine.com . Go to the "shop" click plans and go to page 3. Its on there.
It was featured in the magazine as well so you could (presumably) order that back issue with the plan. This ones a bit bigger you would have to reduce it!
Miles 38 Messenger
Jul 2000 (Vol1/Issue8)
Graham Smith
Class 1 R/C scale design, '60' - '100' engines and 5/6 channel, 100" wingspan.
Price - £22.95
Miles 38 Messenger
Graham Smith
Price - £22.95
