Royal Kits
Old 02-06-2020, 08:20 AM
  #1876
Mtthwacrss
Mtthwacrss's Avatar
I have built several but this is the oldest kit and one of my favorite planes. My uncle built this kit back in the 70 but I didn't get a chance to see any of that build. I just don't want to screw up the wing.
Old 02-08-2020, 05:52 AM
  #1877
scale only 4 me
My Feedback: (158)
scale only 4 me's Avatar
Follow the instructions,, as the wing tapers and airfoil shrinks, the distance between the table and the rib trailing edge is also going to be reduced, Making sure each rib is on the same level plane like the instructions call out will create a straight wing,,, that's why newer kit designs have alignment tabs on ribs
good luck
Old 05-03-2020, 11:39 AM
  #1878
I-fly-any-and-all
  #1879
I-fly-any-and-all
I got the royal hellcat prototype plans scanned and copied by a good friend, will have available for sale soon.
G.F. Reid (04-07-2021)
Old 05-06-2020, 06:33 AM
  #1880
i_soar
i_soar's Avatar
Default Royal Pitts questions
Well, while continue working on my Skymaster I find myself the new owner of a fully ready to fly but unflown Royal Pitts.
Any tips on a docile CG? Any first flight warnings to be aware of? Iím a veteran flyer but know certain planes can be a handfull.
John
Old 05-06-2020, 07:40 AM
  #1881
I-fly-any-and-all
Here are the pitts s1 plans with balance info.
balance is at leading edge of lower wing.
I'd love to see a picture of your model. I have a built and un flown s2.
if you need s2 go here https://outerzone.co.uk/plan_details.asp?ID=9319
Join the royal kits group https://www.facebook.com/groups/1702...624/?ref=share
File Type: pdf
Old 09-14-2020, 12:13 AM
  #1882
I-fly-any-and-all
Anyone got a new project you're working on?
Old 09-15-2020, 08:45 AM
  #1883
Mtthwacrss
Mtthwacrss's Avatar
Still working on the Tony.
I-fly-any-and-all (09-15-2020)
Old 09-21-2020, 01:47 PM
  #1884
GorillaToast
I'm working on a 1938 Rearwin Speedster 6000C based on plans by Bridi. I've made a few adjustments to try and get it more scale-like, and using a fiberglass fuselage, balsa covered foam wings and tail feathers. The way the wings attach on the full-size plane is puzzling me. I have a great picture that shows the cabin side without the wing and it looks like it sits on a wing tube which is what I'm planning.
Old 04-06-2021, 05:02 PM
  #1885
i_soar
i_soar's Avatar
Default Royal Skymaster
Ok, my Skymaster is finally complete. Looking for flight comments from others. Any bad habits to look out for? First flights are always a test of nerves.
John
Old 04-07-2021, 08:50 AM
  #1886
I-fly-any-and-all
What engines are you using?
Old 04-07-2021, 08:51 AM
  #1887
I-fly-any-and-all
Picked up my 4th royal b17, 3rd built one so far.
Old 04-07-2021, 09:53 AM
  #1888
FlyerInOKC
FlyerInOKC's Avatar
Given enough time you could have your own squadron!
Old 04-07-2021, 01:47 PM
  #1889
i_soar
i_soar's Avatar
l have an is 55ax in front and an equivalent electric in the rear. I believe it will likely be able to fly with just the os running. The batteries for the rear are on CG, so there is a weight penalty but I think it is ok. I donít have a weight to offer yet. Need to put it on the scale.
john
Old 04-08-2021, 02:40 AM
  #1890
i_soar
i_soar's Avatar
john
There are always trade offs. The Skymaster all up, balanced and ready to fly weighs in at 11.35 lbs. Yes it is heavier than the plans call for, it required some weight in the nose to compensate for the 3 thin wing servos mounted in the horizontal stab. Given the much simpler linkages and just making servo connections when separating the tail booms it seemed worth it. Also the battery for the rear motor makes up for about 1 lb of the weight. I bet there have been heavier Skymasters fly.
Old 04-08-2021, 04:28 AM
  #1891
FlyerInOKC
FlyerInOKC's Avatar
It looks great!
Old 04-08-2021, 05:25 AM
  #1892
I-fly-any-and-all
I started a royal group on Facebook there is a guy out of Australia that flew his with 2 61s, was a bit squarely.
I remember he had to adjust the thrust on the rear engine a bit but I'll inquire with him.
Old 04-12-2021, 10:10 PM
  #1893
I-fly-any-and-all
from a guy i know and his first hand experience.
Hey man it calls for 0 degree thrust offsets. Flying.... keep fast. She will tip stall as soon as she can. Ass flaps also if you can. On take off make sure you have plenty of speed before you rotate. Thatís what killed mine. Itís self rotated early before we had enough speed. My mate who was flying it, was traumatised and still talks about it.
Old 04-13-2021, 01:05 AM
  #1894
i_soar
i_soar's Avatar
Good to know, do you recall where the CG was located? I have mine a bit forward without fuel. Getting close to flight, just a couple more tinker type things to do then do engine run up.
Old 04-13-2021, 05:04 AM
  #1895
I-fly-any-and-all
Cg is on plans as always 1/3 width of wing from leafing edge back
Old 04-13-2021, 05:07 AM
  #1896
i_soar
i_soar's Avatar
Thanks, CG is set to 3-1/4 behind LE. This is the forward position. Should be good
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
