Reload this Page >
AMR 33% Waco YMF-5 Build
Old 02-02-2013, 02:38 AM
  #2551
VincentJ
VincentJ's Avatar
Default RE: AMR 33% Waco YMF-5 Build
Way to go on the rivets Anthony! They will look so much better than the glue drops. It is slow at first, but you will get into a groove and it will go much quicker... FYI: to get the rivets out of the tray and placed into position, I found it best to use an fresh blade on an X-acto knife and just touch the tip of the rivet and it will pick it up and then you can place it where it needs to go. This makes the process go so much quicker, and in a weeks time your vision even comes back...LOL
Old 02-02-2013, 05:00 AM
  #2552
Cricklewood
What adhesive do you use to attach the rivets to the plane?
Chris
WB # 133
Old 02-02-2013, 05:39 AM
  #2553
WacoNut
WacoNut's Avatar
Chris,
You set the rivet into position and just touch it with a soldering iron for 1-2 seconds and the heat will set the rivet into the primer. Once the plane is painted the rivets are locked into position.
You can see by the pic of VJ's STA above that they really look nice once applied.
Later!!
Anthony
Old 02-02-2013, 07:20 AM
  #2554
WacoNut
WacoNut's Avatar
I sanded the fuselage this morning, overall it is looking good. There were a few pinked edges here and there that needed selaed down.
I took care of the edges that needed attention then sanded the entire fuse and gave it another coat of PolyC. I may give it a 4th coat and a final sanding.
Here are a few pic, Pic #1 is before sanding. Pic #2 you can see the left side is sanded and the right side has not. Pics 3 and 4 are after another coat of PolyC.
I want the pinked edges to be visible but I want you to have to look for them in the finish not protruding thru the finish, not sure if that makes sense or not?
I am going to work on applying some stitching and tapes to the bottom wing panels.
Anthony
ID:	1847104   Click image for larger version
ID:	1847105   Click image for larger version
ID:	1847106   Click image for larger version
Old 02-02-2013, 09:57 AM
  #2555
WacoNut
WacoNut's Avatar
Thought I would post some pics of the rib stitching.
The rib stitches come in 2" wide strips. You cut strips the desired width and apply them over the ribs. Mine are cut .200 wide. I then iron down a tape starting at the T/E and stop just before the 1st stitch. I then use a credit card or such to form the tape over each stitch. If you try and just stretch the tapes over the whole length of the stitching and then iron it down the tape will not conform tightly around the stitch.
Once the tapes are over each stitch I then iron along each side of all the stitches to secure the tape to the stitch. I then iron down the pinked edges of the tapes. The tapes pucker up at each end of the stitch but these shrink out as you iron the pinked edge down. The tape is then pulled around the L/E and applied over the stiches on the top of the wing. It is a bit time consuming but not difficult to do.
Later!!
Anthony
ID:	1847137   Click image for larger version
ID:	1847138   Click image for larger version
ID:	1847139   Click image for larger version
Old 02-02-2013, 10:09 AM
  #2556
acerc
acerc's Avatar
Looking good Anthony. And by the pics the covering has a much tighter weave than Koverall.
Old 02-02-2013, 10:22 AM
  #2557
WacoNut
WacoNut's Avatar
Thanks Robert,
Yeah the weave is much tighter than Koveral. I don't see mysefl using Koveral again after using the fabric.
Snowy miserable day here and perfect for staying inside and working on a plane.
Anthony
Old 02-02-2013, 10:32 AM
  #2558
acerc
acerc's Avatar
So the snow can be a good thing. LOL I will be useing the PolyLite this time as well. From what I see on yours it should fill necely with two or three coats of Polyspray with the amount of aluminum pigment in it.
Old 02-02-2013, 10:36 AM
  #2559
WacoNut
WacoNut's Avatar
If you are going to add tapes you can get by with only 2 coats then build up several more coats after the tapes are applied. Your weave will be filled well and the tapes will blend in.
Later!!
Anthony
Old 02-02-2013, 11:07 AM
  #2560
All Day Dan
All Day Dan's Avatar
Anthony, your descriptions and close ups are great. What camera are you using? Dan.
Old 02-02-2013, 11:14 AM
  #2561
WacoNut
WacoNut's Avatar
Hi Dan,
I am using a Nikon D3000, not the greatest SLR but it does pretty good.
Later!!
Anthony
Old 02-02-2013, 12:27 PM
  #2562
All Day Dan
Got it. Thanks, Dan.
Old 02-02-2013, 01:24 PM
  #2563
WacoNut
WacoNut's Avatar
I finished what I could on one wing panel until my stitching order arrives.
Turned out pretty good. The larger reinforcement tape around the perimeter required an extra set of hands to help hold the wing while I heated and stretched the tape around the wing tip.
The polyc on the fuse is now dry so I will give it another sanding.
Later!!
Anthony
ID:	1847209   Click image for larger version
ID:	1847210   Click image for larger version
Old 02-02-2013, 05:50 PM
  #2564
WacoNut
WacoNut's Avatar
The fuse is finish sanded and it turned out great.
I wound up putting 4 coats of PolyC over the tapes. I believe this will give me the reults I am looking for once the paint and primer goes down. You can feel the pinked edge slightly and the tapes and the covering are nice and smooth. In the pics you can see a shiny area just along the pinked edge of the tape, this is where it is just below the surface of the tape and remained untouched from the sanding.
Back to working on the wings.
Anthony
ID:	1847324   Click image for larger version
Old 02-02-2013, 07:51 PM
  #2565
WacoNut
WacoNut's Avatar
I was able to get the rib stitching and tapes on the other bottom wing panel. I spent a good 14 hrs working on the Waco today and it doesn't seem like I accomplished that much. I will start working on the top wing center section tomorrow and see if I can't get the fuel tank details started.
Later!!
Anthony
Old 02-03-2013, 07:04 AM
  #2566
WacoNut
WacoNut's Avatar
Working on the top wing center section,
I used the old fuel tank to lay out the position of the tank and put the stitching and tapes down. I have aluminum to cut a new simulated tank. The tapes will need 4 coats of PolyC and sanded before the new tank can be put in place. The top wing center section has to be ready for primer and paint before the simulated tank can be put in place. I have several pieces that need PolyC and sanded so that will keep me busy most of the day.
Later!!
Anthony
ID:	1847474   Click image for larger version
Old 02-04-2013, 01:52 PM
  #2567
WacoNut
WacoNut's Avatar
Yesterday I rib stitched one of the top wing panels while I was applying coats of PolyC.
The top wing center section turned out really good after 4 coats of PolyC and a couple sandings. I used roof flashing material to cut a new fuel tank from and roughed up the back side of the aluminum with 150 grit paper and gave it and the center section a skim coat of epoxy. Tape held it in place until today and the tank came out nice. I will give the aluminum a coat of self-etching primer.
I need to start hammering out some more rivets.
Anthony
ID:	1848059   Click image for larger version
Old 02-04-2013, 02:35 PM
  #2568
VincentJ
VincentJ's Avatar
Man that came out nice, I see that your work is being monitored by your kitty!
Old 02-04-2013, 03:53 PM
  #2569
WacoNut
WacoNut's Avatar
Thanks VJ,
Yeah she is the Quality control specialist, I have yet to impress her.
Was going to spray some primer tonight and realised I am out of masking tape. Oh well I will pick some up tomorrow. I also need to pick up some 3/16" dowel rod for building the wing fairing at the back bottom side of the wing saddle. This was a real PITA the 1st time around so hopefully I learned a little from it. The wing saddles will be finished off at the same time and the fiberglass wing fairings installed permenately.
Later!!
Anthony
Old 02-04-2013, 04:51 PM
  #2570
acerc
acerc's Avatar
I feel your pain. But tomorrow is not that far away. Are you going to do the rivets on the tank useing the punching of soda can method?
Old 02-04-2013, 05:16 PM
  #2571
WacoNut
WacoNut's Avatar
Yeah punched out rivets. Can't quite shy away from that after prodding VJ to do them on his STA now can I? I can make a few hundred rivets an hour. I think I will need somewhere between 1400 and 1600. You wouldn't think there would be that many on a fabric covered plane but the aileron's have a bunch of them.
Off to make some rivets[&o]
Anthony
Old 02-04-2013, 05:28 PM
  #2572
acerc
acerc's Avatar
Another question, have either of you tried to do more than one layer of can at a time?
Old 02-04-2013, 05:40 PM
  #2573
WacoNut
WacoNut's Avatar
I haven't but I will. I doubt it will work but hey nothing ventured nothing gained.
Old 02-04-2013, 05:57 PM
  #2574
WacoNut
WacoNut's Avatar
ORIGINAL: acerc
It doesn't work, the sheet on top will punch out fine most of the time but the sheet on the bottom produces distorted rivets.
Once you get a rythem going you can knock the rivets out pretty quick. I can see applying them will be another story. Getting them turned right side up and in the correct position then touching with the soldering iron.
I think I can hear VJ laughing in the distance
Anthony
Old 02-04-2013, 06:08 PM
  #2575
acerc
acerc's Avatar
It was a thought, useless as it may have been. And I can hear him as well.
