Foam rubber for vintage tires? >
Old 06-08-2003, 05:13 PM
Default Foam rubber for vintage tires?
Hi guys.
Williams Bros vintage wheels/tires have always seemed very heavy for electric models. The tire rubber seems to contribute most of the weight to the units.
I've read of vintage wheels hand made using some type of foam rubber for the tires. I can turn the wheels. Can someone tell me what kind of foam rubber is used and where I might find it?
Thom
Old 06-08-2003, 09:26 PM
My Feedback: (9)
Hi, Thom. I have an old book by David Boddington describing making scale wheels and using "Sorbo"as the core or white foam which can be cut & shaped. The book was "Radio Contril Giant Scale Aeroplanes" 1986. It gives detailed account of moulding the tire with lettering.
Cheers
Old 06-09-2003, 05:48 AM
Default Vintage wheels & tires
Thanks Reg. I'll try to look that up. Shall I assume that the publisher would be here in Britain?
Thom
Old 06-09-2003, 02:08 PM
My Feedback: (9)
Argus Books, Hemel Hempstead
ISBN #0-85242-941-X
Its possible that the process could be altered for your intended usage. I would look into some of the building insulating foam or refridgeration insulating foam for your application. Some of it can be turned into shape easily.
Good Luck!
Old 06-09-2003, 06:26 PM
I made some wheel s for the Boddington Sop; Pup , I found a rubber supply co; told them what I wanted , they had different diameters of sponge rubber with a hard skin on outside , see if you can find a place over there ,
Old 06-16-2003, 08:54 PM
R101's Avatar
You can buy sponge rubber cord here
http://www.rcscale.co.uk/materialtools.htm
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
