BUSA DR1 First Flights, Finally! >
Old 06-10-2003, 11:30 AM
Tmoth4's Avatar
Default BUSA DR1 First Flights, Finally!
I finally got a chance to fly my BUSA DR1 last week after waiting weeks for the crap weather around here to get better. It's a great
flying plane! I thought it might be a little squirrelly in the air but it is very solid. The ailerons are more effective than I thought, the plane even rolls pretty nice. Ground handling is another story. The rudder is not very effective when the tail comes down and it will ground loop pretty easy. I tipped it on its nose a couple times but also did a few decent landings too. Ground handling is going to take some practice, but once it's in the air it's a joy!
Model is balanced right where the plans show. Power is a Homelite 33cc chainsaw conversion, a very nice running engine. Model is finished with Sig Koverall, WB poly fill coats, house paint color coats, and Minwax satin seal coat. Weight of the model is about 14#.
Model still needs a pilot and some lettering on the sides of the fuse.
Old 06-10-2003, 11:32 AM
Tmoth4's Avatar
Here's a head on shot.
Old 06-10-2003, 12:07 PM
My Feedback: (67)
smchale's Avatar
That looks great Tmoth!! Add a pilot and a scarf in the breeze and you won't be able to tell it's a model! I've always liked the color scheme for the DR1.
Old 06-10-2003, 12:48 PM
Tmoth4's Avatar
Thanks Sean, the pilot's done but I'm glad you mentioned the scarf. I'll definitely have to add that. I'm happy you like the Dr1 camo scheme. I wanted to do something different than the usual all red ones.
Jim
Old 06-10-2003, 01:27 PM
Default DR1
Tmoth.. looks excellent!.. Maybe I'll see it at Dayton in sept?.. BobH.
Old 06-10-2003, 01:50 PM
Tmoth4's Avatar
BobH,
Yeah, I'm definitely taking it, along with my BUSA Nieuport 28.
I went to the Dawn Patrol event last time and had a blast.
Jim
Old 06-10-2003, 01:59 PM
Default DR1..
Tmoth.. sounds great. I'll try to remember to look for it then... BobH.
Old 06-10-2003, 03:45 PM
Tmoth what did you use to cover and paint you Dr1 with, i am about ready to cover my Flair Dr1, i have used the Nelsons litefab and it works realy good, Your plane looks great and you sound pleased , hope you can help ////
Old 06-10-2003, 04:26 PM
Tmoth4's Avatar
iflewbayou,
I covered the plane with Sig Koverall, stuck down with balsarite and heat shrunk. I filled the weave with Minwax water-based polyurethane, 2 coats right out of the can and a couple more thinned coats. The colors are latex housepaint, some of it sprayed and some brushed on. Then I did a final clearcoat of minwax oil-based satin to seal everything.
Jim
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
