Remote glow - onboard glow - ??
For my SSW D.III project, I have to use something other than sticking my glow battery through a hole in the cowl.
It is a small (1/6th scale) model and there isn't much extra space inside. There isn't much room for panels to control a system and pulling hatches off periodically for system maintenance is unappealing.
What are your experiences & opinions on the various options??
TX
RE: Remote glow - onboard glow - ??
Allan, you might want to try this remote glow starter. I've used several with good success. You can mount the remote location anywhere such as the cockpit floor or inside the cowling. http://www3.towerhobbies.com/cgi-bin...&I=LXBC35&P=ML
I have one of the remote glow extensions on my Legionnaire and it works perfectly. The remote location is in the cockpit. I will say however that a lot of these extension kits are of very poor quality. I use this one from OS:
http://www3.towerhobbies.com/cgi-bin...?&I=LXVBC9&P=7
ORIGINAL: abufletcher
What I like about this OS version is that there is a piece that clips very firmly over just the tip of the glow plug rather than a cheap cap that slips over the whole glow plug. Also the wires are substantially shielded. I tried one of the cheapo units and it literally fell apart.
BTW, another option that works well and that I'm using on my Snipe is a very simple "pig-tail" that attaches to a standard glow starter. Someone here on RCU suggested this. I used one end from an old glow starter charger (the end with the metal bit that clips into the starter) and then put alligator clips on the two wires. One alligator clip is attached to the top of the glow plug and the other to a "ground" position anywhere close to it, such as one of the cooling fins on the cylinder head. This works perfectly for me.
ZACTLY.......OS's clip on is the best i have ever seen.
i also use Sullivan's new Glow Driver, but clipped the caps off right after the first one went south, and replaced with the OS.
it also looks more reallistic too as in has that plug boot look to it.
I honestly prefer to have on-board glow. it is clean, and easy, and you do not have to have the ni-starter. The biggest benefit, especially with the 4-strokes, is you can get your idle set very low and it really improves how your engine runs. Not much of a chance of a deadstick. Which is very important with scale WW1 models.
On-board glow seems like a good option for 1/4 scale and larger. But on a 1/6 scale WWI fighter, things are awfully tight as it is without having to find space for a second battery. On the other hand, the purist could argue that deadsticks were a part of WWI flying. Why shouldn't WE have to experience this as well!
I know we have been here before but I believe there is plenty of room for a battery in 1/6th scale. The battery does not have to be that big and the units are very small. As for going so far as enduring dead sticks because the "real" aircraft did, I do not want to bust up my models unnecessarily. This is just my opinion though. I really feel, once you try on board systems you would not want to go back.
I would prefer to skip the dead stick aspect of WW-I also. On the other hand, space is very tight and access (if necessary) to the battery and control panel is a problem. Specifically what access is actually needed anyway?
I have some specific questions on the posts so far.
OS Booster Terminal Kit:
I assume that the OS Booster Terminal kit has a receptacle for a regular glow starter, except it can be located in the cockpit or elsewhere??
GLOW2F:
I can't get the pdf manual for the GLOW2LP but I assume it is the same as the GLOW4FP except for the number of plugs it would drive??
This unit is a controller for the system and requires leads as well as a battery unit?
Leisure RC Models Glow Driver:
I assume there is a little microchip in the Y-connector that controls the system and can be set for different points?
The battery seems to be included in this one. Is that a C-cell??
I don't see an on-off switch for this one. Does it get turned on by the transmitter or what?
I want to thank everybody for their thoughts. Keep them coming. I still don't understand this thing yet.
GLOW2F:
BTW, I was under the impression that people set up the on-board glow so that the battery only switched on a low throttle.
ORIGINAL: allanflowers
Personally i have two ways of charging, depending on the plane and how it is set up. One, you can splice in a lead that goes to the battery and use a Deans connector or one end of a servo extension, then plug it in to your charger. Two, use alligator clips to the tabs on the battery. There are probably other ways of charging as well but these are the two methods i use, both work fine.
ORIGINAL: OldScaleGuy
Not exactly. Charging through your rx switch will typically only charge your rx battery. The on board glow can be left in the plane but needs to be charged seperately. It is a single cell 1.2v battery. Your rx battery pack usually is 4.8v or 6.0v. Perhaps some pictures would help.... ?
Abu is asking all the same questions I have. If I go with onboard glow, I would want a charging jack hidden in the cockpit or somewhere to avoid having to pull off hatches, etc.
Another question is how does onboard glow affect the starting and handling procedures? I always start by putting my finger over the exhaust and turning the engine to prime it. Then I hook up the glow battery and start it up. I assume the priming would have to be done at high throttle setting anyway but is there an accidental start up problem in other situations?
Also, some systems I have seen on the internet have indicator lights. How necessary is that?
Thanks again for the help and information.
A hidden charging jack is not a problem, you can put a charging jack any place you would put a charging jack for the rx pack. The system does not activate until you push the throttle to full open and then return it to idle. I have not heard of any accidental start ups but any thing is possible. The indicator light is common on most systems. When the LED is on the system is sending a signal to the glow plug to light. I have one plane set up where the pilots microphone is the LED. It was my wifes idea and it worked out well. You can hide them any in a cockpit or not use it if it is too much trouble. I do have one plane set up where i do not use the LED. I can tell it is sending a signal when i rotate the prop and get a "bump" out the engine before starting.
AZ
It might be worthwhile to check out the McDaniel on board glow system. The battery is not large and there is an on board charger available. I have a pumped OS120 FSIII inverted and access to the deep set plug is difficult
and removal of the starter can be downright dangerous. I also have Saito 91SGK that is upright but I don't want to cut a hole in the cowling. McDaniel is available from Sonictronics and are not the cheapest system available.
My Feedback: (13)
I have been using a Centronics Flight Glow II for several years now as an onboard glow unit. It has been totally reliable. The link below has instructions and shows a wiring diagram. I soldered a set of leads with spare battery connector into the onboard glow wiring so I could use a charger rather than a wallwart.
http://www.c-tronicsinc.com/flightgl...ctions4-04.htm
Note that some chargers (AccuCycle Elite for instance - I use this one) do not work properly "edit - charging two batteries at the same time" on a common ground. The receiver battery and the on-board glow battery have a common ground. I actually disconnect the RX battery before charging it and the glow battery.
Brian
Brian
I found a good article on glow drivers. It covers most of the things you folks have already discussed.
http://findarticles.com/p/articles/m...8/ai_n8974269/
I am leaning toward this set up. It includes the battery, has a separate indicator and seems to have good features.
http://sonictronics.com/xcart/produc...cat=310&page=1
Thanks much! Any more ideas, please post before I buy anything.
