RCU Forums
-   RC Scale Aircraft (https://www.rcuniverse.com/forum/rc-scale-aircraft-169/)
-   -   William Bros Wheels (https://www.rcuniverse.com/forum/rc-scale-aircraft-169/11073894-william-bros-wheels.html)
AM6 05-09-2012 12:44 AM
William Bros Wheels
All,
Can anyone help...
I need to find some 'thin' 5" wheels for a warbird project that I am currently building.
In my quest for the 'thinnest wheels' I have come across the William Bros 'Golden Age' design.
Question...The model will probably turn out @ 30lbs in weight and I wondered if these would be sufficient for the Job...Has anyone had any experience with these wheels?
All comments welcome.
AM6
N1EDM 05-09-2012 02:03 AM
RE: William Bros Wheels
I can't speak for Williams Brothers wheels but if you don't get a source to pan out, you might try some Dubro Vintage wheels and see if they will meet your needs.
Here's a link to a typical set:
http://www3.towerhobbies.com/cgi-bin...?&I=LXKLV1&P=7
Just my $.02
Bob
TomCrump 05-09-2012 03:41 AM
Williams Bros wheels now come with an "inner liner" that should hold up to the weight of your model. I purchased a set, for a 35# warbird. I sold the warbird and mounted the wheels on my Cessna Airmaster, which weighs 23#.
JohnF 05-09-2012 05:43 AM
You are in the UK, so why not try Mick Reeves or Toni Clark?
US185Damiani 05-09-2012 11:05 AM
AM6 you are looking for Williams Bros Smooth Contour wheels. they are the thinnest in overall width and are set up with a smooth cover.
Here's a link
http://www.ebay.com/itm/NEW-Williams...item4cfcc29ecc
Prop Nut 05-09-2012 03:33 PM
Tom, did those wheels come with air fittings? :D
TomCrump 05-10-2012 04:04 AM
1 Attachment(s)
No air fitting, David. The "inner liner" is foam, I believe. It solidifies the wheel so that it won't sag under the heavier weights of larger birds.
DuBro has the air fitting type.. Mine leaked on the Stuka. I replaced them with "solid" wheels.
mgnostic 05-11-2012 08:22 PM
Why not ask the source. I spoke with the guy who runs William's Bros. a couple of years ago. He was very willing to discuss applications.
AM6 05-13-2012 11:51 PM
All,
Thank you very much for your input.
In the end I have now chosen tofit the wheels that I originally had which are Williams 'Baloon style' in 5.25inch.
The 'weight/very thin tyre' aspect worries me, and I need something functional on a model that has less than ideal ground handling characteristics.
Basically this has held the project up for a number of weeks now and I just want to 'crack on' and I have magaged to squeeze these in with zero room to spare..
Unfortunately this has meant that I have to go through the upper wing surface, and am going to make larger than scale blisters to suit.
Happy Landings.
AM6.
