Scale panel lines
Hey guys! How do i put scale panel lines on a fiberglass wing? I dont want to use tape or markers ! This is for a giant scale warbird. Any help would be great! stash
RE: Scale panel lines
The standard procedure is to lay thin strips of tape down on the panel lines, then spray with primer until the tape is covered. Next, you carefully sand down until the tape is exposed, then VERY carefully peel up the tape, leaving behind a recessed panel line.
Thanks for the info!
ORIGINAL: stash4466 Thanks for the info! Jim |
If you want truly scale panel lines buy a roll of FliteMetal and make the actual panels.
Have been looking for some kind of tutorial on how to go about doing the tape and making lines etc. Any help here ??
2 Attachment(s)
Originally Posted by TerryW
(Post 11726251)
Are you looking for butt joints, or overlap joints ? The Stuka, picture below, has butt joints, using 1/64" tape.. The Cessna wing has overlapped joints |
I build WWII type aircraft, but they use both styles, overlap and butt joint. I will be doing a Spitfire as my main focus, but am going to practice doing a P 51 first.
I also forgot to ask where would you get 1/64 wide tape ?
(Post 11726626)
(Post 11726625)
I find that if you wait until the primer is fully dry, that I run the risk of tape, and tape residue, being left behind on the airframe. Overlap panels take some planning. On a fuselage you have to start at the bottom, and at the rear. Tape is placed on the rear/lower panel, and paint is built up on the forward panel. An airbrush is excellent for this type of work. On wings, I start at the most rearward panel. If you have long, straight lines you can paint more than one panel at a time. I work in one axis at a time. On a wing, I start span wise and work towrds the leading edge. Then I start at the wing tip, and move to the wing cord.. This may explain it a little better. I go through the process, with pics, starting here: http://www.rcgroups.com/forums/showt...005782&page=74 |
8 Attachment(s)
Back sometime ago I perfected the art of scribing pannel lines and rivets for my 1/5th scale Mustang. They are cut in to the primer prior to painting, the lines are .012 thousandth" wide. I made the tools to do it out of dental picks and brass tubes.
Originally Posted by Leroy Gardner
(Post 11726963)
Originally Posted by OldScaleGuy
(Post 11727526)
Leroy, can you give us any more details about the tools and the process?
Leroy |
Found and book marked. Thank you! Maybe the link will work from this computer.
http://www.rcuniverse.com/forum/tips...es-rivets.html |
(Post 11727561)
http://www.rcuniverse.com/forum/tips...es-rivets.html Leroy |
12 Attachment(s)
(Post 11726251)
P51 taped, primed and then a few of how it looks after paint and weathering. On the tail of the Zero you can see a combination of the chart tape and layered painter's tape to give me both the fillet panel around to forward root of the vert.stab and panel lines on the rest of the stab. On the wing there is a bunch of HVAC foil tape which is great for doing access panels, hatches, inspection covers, etc. Entire A/C gets a silver base coat so when the weathering is done and color is lightly sanded away, edges chipped etc it really makes things "pop"...especially the foil tape accents since it really is real aluminum showing through. http://www.rcuniverse.com/forum/atta...mentid=1966462http://www.rcuniverse.com/forum/atta...mentid=1966463http://www.rcuniverse.com/forum/atta...mentid=1966464http://www.rcuniverse.com/forum/atta...mentid=1966465http://www.rcuniverse.com/forum/atta...mentid=1966466http://www.rcuniverse.com/forum/atta...mentid=1966467http://www.rcuniverse.com/forum/atta...mentid=1966468http://www.rcuniverse.com/forum/atta...mentid=1966469http://www.rcuniverse.com/forum/atta...mentid=1966470http://www.rcuniverse.com/forum/atta...mentid=1966471http://www.rcuniverse.com/forum/atta...mentid=1966472http://www.rcuniverse.com/forum/atta...mentid=1966473 |
Thanks for posting the pics, frets 24. I deleted mine, long ago.
Nice work on those birds ! |
Thanks, Tom!
I save all of my pics both on the sd card and on a disc as well as two seperate drives on the computer......Yes, I'm a hoarder!!! Learned about redundancy the hard way and since I know a percentage of our planes will unexpectedly expire and rekit themselves it's nice to have the pics to remember them by. |
How do you guys cut out those perfect circles from the aluminum tape? Even with a new blade it always seems to grab and tear.
Originally Posted by fly20
(Post 11733403)
(Post 11733403)
1 Attachment(s)
Originally Posted by frets24
(Post 11734012)
Scribe the circle using a circle template and a good sharp pencil then cut out with scissors. Look at it from the backside after to see where it might need to be trimmed or shaped up...easier to eyeball the shape without the glare.
I've also sharpened cut off pieces of wing tubes. Place the sharpened end on the aluminum and smack the other end with a hammer. It's a poor man's die cutter. LOL You can see one on the fuselage of my Stuka, just below the elevator control horn, in the attached pic. |
Thanks guys. I'll give all the techniques a try.
| All times are GMT -8. The time now is 10:12 AM. |
