Robart hinge points
Can someone please recommend the correct Robart hinge point size to use on a Sig 1/5 scale J-3 cub. I believe that there arethree different sizes - 3/32", 1/8" & 3/16. Thanks. Ken |
RE: Robart hinge points
The standard middle ones will be fine.
Thanks, Thayer.
For a 1/5th scale plane i would use the large hinge points.
Normally I would as well, though for a Cub the stresses will be pretty minimal. I figured if he was walking into a LHS the regular would be the most likely found there and would certainly be up to this task.
Thayer |
| All times are GMT -8. The time now is 06:36 AM. |
