Scale Static display 4 blade props
I am in need of a scale 4 blade prop for a Top Flite 62 inch P51. Any ideas as to where I can order order one, or if sombody has one for sale, let me know [email protected]. Thanks
RE: Scale Static display 4 blade props
Why buy (if one is even available) when you can make your own:
http://www.renderwurx.com/rc/SBD/html/paint/prop.htm |
I assumed BTW that you meant a scale "static" prop.
1 Attachment(s)
How about this one? I carved the blades from bass wood and turned the spinner from a balsa block.
Mike |
Tower Hobbies has them for their P-51's and P-47's. Page 87 in the 2004 catalog or check www.towerhobbies.com.
You can order one from here: [link]http://www.aerotechmodels.com/static.htm[/link]
:)Thanks for all the reply's, I am ordering one now. TOPSIDE
1 Attachment(s)
I made this one from the T.F Blades and turned the spinner from wood then drilled the holes.some paint decals then your done.It was the cheapest way at the time._Mike
| All times are GMT -8. The time now is 12:51 AM. |
