glassing?
wow! what a lot of work, but totaly satisfying. kinda new to it so any tips (and i mean any tips) would be helpful.
RE: glassing?
Tips in relation to what portion of it. It is a lot of work, but very rewarding.
RE: glassing?
any/all portions. but start at the begining. I'd love to learn as much as possible.:D
RE: glassing?
Here are some online resources for fiberglassing.
http://www.airfieldmodels.com/inform...nish/index.htm http://www.tompierce.net/rcplanes/glasstest/index.htm http://www.arts-hobby.com/fiberglassing.htm http://www.daveplattmodels.com/Videos/index.htm I am working on my first glassed plane. I used .5 oz cloth and West Systems epoxy. I am very happy with the results. Here are some of the techinques I used. I used a sanding sealer on the balsa to limit the amount of epoxy absorbed. I thinned the epoxy with with 1 part denatured alcohol to 4 parts epoxy. I applied the epoxy with a brush and used a body putty applicator to squeegee off excess epoxy. I used a roll of toilet paper which I rolled over the surface to remove even more epoxy. To fill the weave after the glass has cured, I used a high build sandable primer. I sprayed the entire surface then used 320 grit to wet sand most of it off, repeating the process until I had a smooth, texture free surface. After filling the weave, I sprayed a constrasting color primer and sanded it down. This leaves color in all the low spots which I then filled with spot filler that comes in a tube from the auto parts store. You can see photos of my build at various stages in my gallery. Scott |
RE: glassing?
thank you so much. im going to check it all out.:D:D
RE: glassing?
scott the pictures you have in you r gallery are great. great job. thanks for the help.
| All times are GMT -8. The time now is 08:06 AM. |
