RCU Forums
-   RC Scale Aircraft (https://www.rcuniverse.com/forum/rc-scale-aircraft-169/)
-   -   Flying Wire (https://www.rcuniverse.com/forum/rc-scale-aircraft-169/8192-flying-wire.html)
Spitman 10-23-2002 02:38 AM
Flying Wire
I am building a 40 sized Tiger Moth and would like to know what to use for flying wire. I would prefer something that can be crimped versus soldered.
Pete
LesUyeda 10-23-2002 09:17 AM
Flying Wire
The fishing tackle stores sell a stainless steel leader that is plastic covered, along with "lead"?? ferrules for crimping. Works fine.
Les
dr_wogz 10-23-2002 11:44 AM
Flying Wire
Ive seen some bipes use elastic cord instead of wire. No need for tuning, no need to fiddle with turnbuckles & etc.. just stretch and hook into position!
Johny 11-12-2002 01:28 AM
Flying Wire
On my .75 sized Sopwith Pup I used tennis racket nylon string. I glued nylon clevises on both ends with cyano and used textil dye to get right colour. It looks really good - click here for picture
FHHuber 11-12-2002 01:43 AM
Flying Wire
You can use just about any string or thrread of the correct size. (#8 builders twine would be a bit oversize... [img]i/expressions/face-icon-small-wink.gif[/img] ) I've used Fishing line or stranded steel "Control Line" flying wire.
The Tiger's flying wire rigging pattern can be done in one continuous string, with a rubber band tensioner at the LE of the lower wing inside the fuselage, or in the false fuel tank in/on the upper wing. Because of this, if you plan ahead you can make things quite easy on yourself for hooking the wires up at the field. (for a sport scale plane, competition scale needs the turnbuckles and other details...) Eye bolts on the upper wings, and J hooks on the lower would allow quick connection. A couple of rubber bands and some Christmas ornament type hooks will hold the disconnected wires wrapped over the upper wing and prevent tangling when the plane is dissasembled for transport..
