Balancing a pusher?
One of my long-term projects is an RAF FE2b two-seater pusher. I've been doing a bit of research and started wondering how those WWI pushers were balanced. If it's the usual 25-30% MAC then that's a definitely a building challenge what with the engine behind the CG.
RE: Balancing a pusher?
1 Attachment(s)
what makes you think it would be any different?
aerodynamics doesn't change.................the engine is pretty much dead center thus making it even easier to do this model. we have 2 DH2's at our field and balance exactly as the typical front engine models of the time period. |
Note to self: Never post after a night without sleep and fully jet-lagged! :D
ORIGINAL: abufletcher Note to self: Never post after a night without sleep and fully jet-lagged! :D this is a very interesting project...........i love reading your threads as i do believe we all get better educated on design ideas we never really think about. i for one am obsessed with researching the fabrication of WW1 planes and the techniques used in that time period................then of course being a Millman by trade, anything wood related gets my curiosity up. |
If the fuel tank is aft of the CG, you would balance it with the fuel tank full. If not it will have a very aft CG at TO; as the fuel burns the cg goes forward.
Ideally, the engine would be on the CG but that would require a drive shaft extension. So does anyone know of a company that makes these extensions for 90-size engines?
Do like this guy and make one:) http://www.rcscalebuilder.com/forum/...077&PN=2&TPN=6
It is one of the hardest thing to make work, models or full. How much of an extension do you think is needed? |
It seems the power boat guys do this all the time, and will sizable engines.
ORIGINAL: TFF Do like this guy and make one:) http://www.rcscalebuilder.com/forum/...077&PN=2&TPN=6 It is one of the hardest thing to make work, models or full. How much of an extension do you think is needed? |
| All times are GMT -8. The time now is 03:57 PM. |
