Stuka plans/kit?
Hey all. I just started poking around for a set of Stuka plans or a good short kit. I'm planning on the Stuka G variant, which means I can't use the stock cowl/canopy in most full kits.
I was just at RCWarbirds, and every single Stuka was from Ziroli plans. Is there anything else out there? I'd like to keep it around 80". Thanks! -Joe |
Stuka plans/kit?
Royal/Maratuka makes one a bit smaller. You could probably blow up the plans.
Stuka plans/kit?
cant u reduce the ziroli?
Stuka plans/kit?
I think Great Planes has an Arf that is around that size. Maybe you can modify it?
Mace Gill The Aeroplane Works |
Stuka plans/kit?
Originally posted by Ragz cant u reduce the ziroli? The Great Planes Stuka arf is a .40 size model, isn't it? -Joe |
| All times are GMT -8. The time now is 05:53 PM. |
