Go Back  RCU Forums > RC Boats > RC Scale Boating
Reload this Page >
Wooden Cracker Box (Ivan Bourdier)
RC Scale Boating Enjoy rc scale boating? Talk about it here.
Old 10-01-2010, 12:23 AM
gtopillado
gtopillado's Avatar
Default Wooden Cracker Box (Ivan Bourdier)
Just wanted to post a build that I have going on. Boat was built by Ivan Bourdier with Birch, Walnut and Mahogany, he did an incredible job and I'm very happy with his craftsmanship. Since I've received it I started to work on the finish, added clear and will also add paint to give it a more scale appearance. Drivers have been cut and reglassed and will start on them very soon. She's getting a Suicidal motor with a Quickdraw pipe, she will move. Pics are coming.....
Old 10-01-2010, 12:45 AM
gtopillado
gtopillado's Avatar
Default RE: Wooden Cracker Box (Ivan Bourdier)
Here's some pics of build....
ID:	1509129   Click image for larger version
ID:	1509130   Click image for larger version
ID:	1509131   Click image for larger version
ID:	1509132   Click image for larger version
ID:	1509133   Click image for larger version
ID:	1509134   Click image for larger version
ID:	1509135   Click image for larger version
ID:	1509137   Click image for larger version
Old 10-01-2010, 09:09 PM
DONS BOAT WORKS
DONS BOAT WORKS's Avatar
Nice.
Old 10-02-2010, 05:45 PM
gtopillado
gtopillado's Avatar
Pics from painting today...
ID:	1509959   Click image for larger version
ID:	1509960   Click image for larger version
Old 10-04-2010, 11:08 AM
gtopillado
gtopillado's Avatar
Some more progress over the weekend. Worked on fit and finish for center skag, its all glassed in and has a little carbon fiber to add to looks and strength. Really happy how it all came out, exactly to Mr. Ivans recommendations, check it.....
ID:	1510890   Click image for larger version
ID:	1510891   Click image for larger version
ID:	1510892   Click image for larger version
ID:	1510893   Click image for larger version
ID:	1510894   Click image for larger version
ID:	1510895   Click image for larger version
ID:	1510896   Click image for larger version
Old 10-05-2010, 07:27 AM
Tidnab
My Feedback: (51)
Tidnab's Avatar
Are Ivan's crackerboxes raceable in IMPBA and NAMBA as it has the non trip chines, instead of a sharp chine as a real crackerbox has ? Both organizations basicially say that the lines of the hull must conform to the lines of a real crackerbox.I've looked at pics of real crackers and all have a sharp chine.The only boat I found that has the non trip chines is the smaller class J runabout.This would give you an advantage over other boats,as your's would be less susceptible to barrel rolling in a fast turn.Some run a non trip trim tab on the left side of the transom to help in the turns. He does make beautiful boats and I especially like the curve from the deck to the side in the rear.
Old 10-05-2010, 10:33 AM
gtopillado
gtopillado's Avatar
Not sure about IMPBA rules as I run in NAMBA and they are legal race boats. They are one of the fastest Cracker box's out there but its more than the sides.....lets just say the bottom of hull isn't just flat. Its what makes them work without trim tabs to keep them on the Lake, even at full speed. I will race my boat but it will not be a dedicated work horse as it would get banged up too much. I'm building "Schon" more for SAW and curious on how fast I can make her...and yes she's got a name now. Record is around 59ish.
I also have a Mono Project Y from Ivan and it flat out hauls, low 60's all day long and turns at full throttle....no trim tabs but 1 turn fin.
Old 10-05-2010, 10:32 PM
Fodigo
Nice looking boat - that deck is sweet.
Old 10-08-2010, 03:02 PM
gtopillado
gtopillado's Avatar
Thanks for the compliments. Here the latest, stuffing tube is in place so I can now finish painting her.
ID:	1512865   Click image for larger version
ID:	1512866   Click image for larger version
ID:	1512867   Click image for larger version
ID:	1512868   Click image for larger version
ID:	1512869   Click image for larger version
Old 11-07-2010, 09:56 PM
gtopillado
gtopillado's Avatar
Thought I'd post some pics of where my build is at. Taking me a while to get the time to make sure its done right but its moving along. Dudes are painted and most of mechanical hardware is fitted, waiting on pipe to come back from my coating connection and than can start working on electronics...
Old 11-13-2010, 02:48 PM
Nosedragger
ORIGINAL: Tidnab
I think it depends on the district, in classic cracker I would protest the hull.With non trips its just another mono.
Old 11-16-2010, 12:08 AM
gtopillado
gtopillado's Avatar
Last thing I'm worried about is protest...most will be upset just for the fact that I'm faster than they are and will look at anything they can to not race against it. Seen them run against other styles CB's and its more than a side trip that make them fly lol. If you want to debate if its legal or not....do it on your on thread as this is my build thread.
Got radio box fasten in, used a 1/8 piece of rubber to give it some protection form vibration. QD Deep Vee pipe came back from my guy that does ceramic coating. Coming along....
Old 11-28-2010, 06:37 PM
gtopillado
gtopillado's Avatar
Great weekend to work on CB, been raining here in No. Ca.. Got a lot done and now I'm in final assembly, waiting for a few things to finish but took a big leap forward. Radio electrics are 99% complete, just waiting on radio box seal. Need IV bag and a friend to weld my exhaust water outlet than I can finish with assembly. Should be firing it up soon.....check it.
Old 12-05-2010, 03:05 PM
gtopillado
gtopillado's Avatar
All done...been a blast building and now the tuning begins. here's some pics of it completed...
ID:	1530677   Click image for larger version
ID:	1530678   Click image for larger version
ID:	1530679   Click image for larger version
Old 12-10-2010, 06:08 PM
DONS BOAT WORKS
Very nice.
Old 12-10-2010, 06:38 PM
gtopillado
gtopillado's Avatar
Thank you. Been getting it dialed in and have more to go but running stable in turns and topping out at 57 mph so far with only 1 blow over. Done a couple things different than last pics and is working very well.
Old 04-07-2011, 12:24 AM
gtopillado
gtopillado's Avatar
Against wife's wishes, I raced her last weekend. She ran well, but had a tough time trying to take it easy as I didn't want her to get banged up. It was really nerve racking but had a great time with my chums. Not planning on running her in a race again but know she is a contender. Ivan really know's how to build a race boat.....looks are a bonus.
Old 04-07-2011, 06:22 AM
advanced builder
advanced builder's Avatar
ORIGINAL: gtopillado
Against wife's wishes, I raced her last weekend. She ran well, but had a tough time not going all out and being nervous about it. It was really nerve racking but had a great time with my chums. Not planning on running her in a race again but know she is a contender. Ivan really know's how to build a race boat.....looks are a bonus.
you lost me on the last post, who built the hull you or Ivan. Whatever ,good job. nice deck she's a looker. Speed wise, she moves right along.
Old 04-07-2011, 03:08 PM
gtopillado
gtopillado's Avatar
The boat builder is Ivan Bourdier. You get a empty hull when you order one from him, than you build it. Sorry for the confusion......
Old 04-08-2011, 09:43 AM
TCHedOff
How much do they cost?
Old 04-09-2011, 09:26 AM
gtopillado
gtopillado's Avatar
About 400 shipped is what I remember. Ivan may have increased his rate by now.....
