Go Back  RCU Forums > RC Boats > RC Scale Boating
 Scratch Built Shrimp Boat. >
RC Scale Boating Enjoy rc scale boating? Talk about it here.
Old 08-20-2011, 09:36 AM
  #76
blizard05's Avatar
Default RE: Scratch Built Shrimp Boat.
I can get them flying or sitting. The flying ones come with a pin to stick into things. LMK and I'l get a price Larry
Old 08-20-2011, 10:02 AM
  #77
wayne d's Avatar
ORIGINAL: blizard05
Thanks Larry, I'll let you know.
Old 08-20-2011, 03:28 PM
  #78
wayne d's Avatar
Stuffing box came today. Then I started looking at the keel and noticed that the rudder would have to be built and installed prior to glueing the keel to the formers. So to fix that I cut the bottom of the keel and made a removable shoe like the Midwest lobster boat.
The stuffing box is glued in with Hysol and drying. As soon as thats dry, I'll mix up a little bondo and fill the groove in.
ID:	1651124   Click image for larger version
Old 08-20-2011, 04:07 PM
  #79
Apismelifera's Avatar
That's what I'm talking about.
Then I could use the regulator to dial down the voltage for the brightness. I think?
Yes you can. The easy way with one of these
http://www.dimensionengineering.com/DE-SWADJ.htm
and you might like one of their breakout boards too.
Old 08-20-2011, 04:16 PM
  #80
wayne d's Avatar
I need to go through the site a liitle more but that one looks good. best part, its all plug and play.
Old 08-21-2011, 10:01 AM
  #81
wayne d's Avatar
Keel is glued in and sheeting started.
ID:	1651408   Click image for larger version
Old 08-21-2011, 02:14 PM
  #82
wayne d's Avatar
The rear half of the hull is sheeted. The rear half is glassed inside with 3oz glass and Z-Poxy and the oil/grease tube is installed.
Now on to the front half.
Old 08-21-2011, 04:56 PM
  #83
You're just moving right long with this one, aren't you?
Old 08-21-2011, 05:07 PM
  #84
Love what you did with the keel. Thinking on your feet again I see.
Old 08-21-2011, 05:55 PM
  #85
wayne d's Avatar
ORIGINAL: rblubaugh
Just rolling on the bayou.
Old 08-21-2011, 05:56 PM
  #86
wayne d's Avatar
ORIGINAL: QuickLTD
Thanks Quick
Old 08-21-2011, 05:57 PM
  #87
wayne d's Avatar
One side of the hull finished, or at least sheeted.
Old 08-22-2011, 03:56 AM
  #88
wayne d's Avatar
Here is what I done with the cabin tops. All held on with earth magnets.
ID:	1651920   Click image for larger version
ID:	1651921   Click image for larger version
ID:	1651922   Click image for larger version
ID:	1651923   Click image for larger version
ID:	1651924   Click image for larger version
Old 08-22-2011, 06:11 AM
  #89
wayne d's Avatar
Just to let everyone know, I found a source for nets.
Butterfly nets.
Old 08-22-2011, 06:13 AM
  #90
Now that is <span style="font-size: large;"><u>really</u></span> neat. The magnets, that is.
Old 08-22-2011, 06:28 AM
  #91
That cabin profile looks really good with that hull design.  Looks like "they were made for each other" LOL
Old 08-22-2011, 06:51 AM
  #92
wayne d's Avatar
Before I closed up the hull I added a 1/4" thick block at the bow. This will let me attach the rigging to the net booms.
Old 08-22-2011, 06:54 AM
  #93
wayne d's Avatar
I finished sheeting the hull this morning and filled the seam lines.
ID:	1651954   Click image for larger version
Old 08-22-2011, 07:13 AM
  #94
Wayne,
It would be a good idea to coat all the Luan with thinned epoxy so it will soak in.  The glue used on it is interior grade and therefore not waterproof.  I don't know if you are going to treat the forward part of the hull like you did the aft section or not but when/if you do be sure to cover all of the Luan.  Moisture can seep in just from the air and cause problems so it needs to be sealed.
Bob
Old 08-22-2011, 07:59 AM
  #95
wayne d's Avatar
Just got it done.
Old 08-22-2011, 08:27 AM
  #96
Looks fabulous.
Old 08-23-2011, 12:28 AM
  #97
wayne d's Avatar
OK Guys, time to put on the thinking caps and shoot some idea's this way.
I'm trying to come up with a few ideas about how to raise the net booms up and down. I'm way out of my league here.
So far I have two,
One is using a sail servo, but I'm not sure if it has enough travel.
Second, I'm thinking about a continious rotation servo with some sort of drum to hold the kevlar line.
Pros and Cons anyone.
Old 08-23-2011, 03:47 AM
  #98
blizard05's Avatar
ORIGINAL: wayne d
So far I have two,
NO 2 and a spool from a sm spinning or fly fishing reel
Old 08-23-2011, 05:38 AM
  #99
Have you seen these winches?  They seem to get great reviews.  Not sure if they hold enough line for your needs.
1/10 scale size
http://www.rpphobby.com/product_p/3racr01-27.htm
Same 1/10th scale winch as above but the same supplier as the 1/8th below it
 http://www.ckrccrawlers.com/3racing-...er-p-2983.html
1/8th scale size.
http://www.ckrccrawlers.com/3racing-...ze-p-2984.html
The video gives you a good sense of the speed
http://www.youtube.com/watch?v=VcWmI53L0dY
This one shows you how to change the line.
http://www.youtube.com/watch?v=sLFkhG6gNKM<br type="_moz"/>
Old 08-23-2011, 11:54 AM
  #100
wayne d's Avatar
ORIGINAL: blizard05
ORIGINAL: wayne d
So far I have two,
Can the servo be stopped at any point by the use of a control stick or knob on the transmitter?
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
