Go Back  RCU Forums > RC Boats > RC Scale Boating
Reload this Page >
Scratch Built Shrimp Boat.
RC Scale Boating Enjoy rc scale boating? Talk about it here.
Old 08-29-2011, 12:59 PM
  #126
rblubaugh
Default RE: Scratch Built Shrimp Boat.
I took a look back to visualize the shrimp nets, at least those up against the cabin.  I'm anxious to see the results.
Old 08-29-2011, 04:55 PM
  #127
blizard05
blizard05's Avatar
You can modify any servo to continues rotation. Oppen it up,look at where the finel drive is,you will see a sm box,with shaft sticking out,remove cover from top of box remove drive shaft from housing,remove coper contact from shaft,remove stop from cover " high spot" on under side Try it with an old servo first Larry
Old 08-29-2011, 06:47 PM
  #128
wayne d
wayne d's Avatar
Hey Larry, Glad you made it through the storm ok. Sounds like inland got the brunt. Thanks for the info on the servo, I'll look around and see if I can find one. Normally I just throw them away when they break or go bad.
Old 08-29-2011, 10:08 PM
  #129
wayne d
wayne d's Avatar
Here is where i got the idea for a black hull with a white cabin.
Old 08-29-2011, 10:12 PM
  #130
blizard05
blizard05's Avatar
Looks too nice for a working boat,are you going to add some aging to it??
Old 08-29-2011, 10:32 PM
  #131
wayne d
wayne d's Avatar
ORIGINAL: blizard05
I've never weathered a boat before, but I'm going to give it a try.
Old 08-30-2011, 02:23 AM
  #132
blizard05
blizard05's Avatar
By the time it got up here the winds were off shore, from the West.We had some wind dammage,verry little rain,had worst storms last Winter ( I HATE SNOW ) I did my ORCA with water based paint, I washed it down with the dirty water I cleaned the brushes with. Some use the model RR paints Larry
Old 08-30-2011, 06:07 AM
  #133
rblubaugh
Wayne,
I'm currently substitute teaching but if you find an old servo go here for some instruction: http://www.ranchbots.com/club/papers...20Rotation.pdf
Bob
Old 08-30-2011, 06:09 AM
  #134
rblubaugh
School system is sloooow.  Happy to hear everyone is alright after Irene.
Old 08-30-2011, 12:18 PM
  #135
wayne d
wayne d's Avatar
Thanks for the info Bob. I'll read through it and decide if I want to tackle something like that. At servo city, one of the options is to buy it already converted.
Here are a couple of pictures of the motor being mounted.. All the brass tubing I ordered is in for the booms. As soon as I finish up the motor and mount the cabin I'll start soldering some brass.
ID:	1655252   Click image for larger version
ID:	1655253   Click image for larger version
ID:	1655254   Click image for larger version
Old 08-30-2011, 06:01 PM
  #136
Apismelifera
Apismelifera's Avatar
ORIGINAL: wayne d
Here is my thoughts let me know what you guys think.
I plan to use and old 7 channel radio I have.
Now if I use a continuious rotation servo, The servo will only move when a control stick is moved, Correct?
If I move the control stick one direction the servo should move in that direction and if I move it the control stick the other way the servo should reverse direction. If the way I understand this is correct, the servo will not move until a input is given, in this case by the control stick.
My plan was to use the throttle for the motor, rudder for rudder, elevator stick for the nets, and one of the dials or switches for the lights.
Will this work?
Sure, it will work. Make sure you have a radio that is legal for surface use. Nobody wants their fun terminated by the FCC because some body complained.
Old 08-31-2011, 06:15 AM
  #137
rblubaugh
I'm sure you've looked at the HSR-1425CR Continuous Rotation servo at Servo City. I was impressed with the dead-band increase to help eliminate creep. Don't remember if it was the article I sent or not but I was reading a couple of the articles about converting servo's and noticed in their videos that they definitely did creep after they stopped moving. That would be pretty noticeable on a net boom.
Old 08-31-2011, 07:44 PM
  #138
wayne d
wayne d's Avatar
Hey Bob,
I looked at it some time ago. I'm close to needing one so I'll take a look again.
What about pullies for the booms? Any great ideas.
Old 08-31-2011, 08:26 PM
  #139
wayne d
wayne d's Avatar
I may have answered my own question..........
http://www.proctor-enterprises.com/p...s/pulleys1.htm
Old 09-01-2011, 06:20 AM
  #140
rblubaugh
I agree, you have answered your own question.  Some nice pullies and the right size I think.
Old 09-01-2011, 01:25 PM
  #141
wayne d
wayne d's Avatar
Here is what I got so far.
Lots of figuring things out and staring at it for long periods of time. [&:] The booms have yet to be soldered, still deciding about length and size of tubing.
Everything has been ordered, I think. Still undecided about the radio. I could use the futaba 7 channel I have and all I have to buy is a battery. Problem is, its an air radio. Good thing for me is there are no flying fields within 10 miles. Or I could use my JR 9303 2.4 and it would not matter. All I have to buy is a receiver.
ID:	1656194   Click image for larger version
ID:	1656195   Click image for larger version
ID:	1656196   Click image for larger version
ID:	1656197   Click image for larger version
Old 09-01-2011, 01:29 PM
  #142
wayne d
wayne d's Avatar
Just for a reference the upright structure is 3/8 tubing with 1/16 music wire for the braces.
Old 09-01-2011, 02:00 PM
  #143
wayne d
wayne d's Avatar
here is a few more.
ID:	1656228   Click image for larger version
ID:	1656229   Click image for larger version
Old 09-01-2011, 03:55 PM
  #144
rblubaugh
I was looking at what you have and the scale of the booms looks to be about right. I'm not sure about the height/boom length, might be right. You probably know better than I.
The one observation I have for you is on all of the shrimp boats you have given as examples the net booms, when lowered, are above the gunwales, yours are resting on the gunwales. You need to raise the pivot point above the gunwales. The lines will hold the "basically" horizontal to the water for the purpose of seining shrimp.
Old 09-01-2011, 04:46 PM
  #145
wayne d
wayne d's Avatar
Hey Bob
Good catch on the booms. My thoughts were I should have some sort of mechanical stop for the booms as they go down. This, at least in my mind would take any pressure off the servo. I could move the pivot point up to the top of the cabin and then install some sore of stops I suppose.
Old 09-02-2011, 05:42 AM
  #146
rblubaugh
It's really difficult to tell from the pictures because of the angle but I think half to two-thirds of the way towards the top would be adequate. As far as strain on the servo is concerned you'll probably be using double blocks and tackle to make the raising and lowering more realistic. I would think that would reduce the strain on the servo when it is stopped? I do sometimes get confused but multiple double blocks are supposed to make the work easier even though the ultimate amount of energy expended is the same, isn't that right?
There could also be drop down braces that drop down to the deck of the boat as the net booms are lowered? How do the real shrimp boats do it? Just stop the winches?
Old 09-02-2011, 10:16 AM
  #147
wayne d
wayne d's Avatar
ORIGINAL: rblubaugh
I wish I could answer either question[&o]
Old 09-02-2011, 12:05 PM
  #148
wayne d
wayne d's Avatar
I decided to go ahead and put a couple of stops on the booms and sort of made them to fit in with the existing structure.
My 12V battery arrived and I put it in the rear cabin compartment. Then I checked the CG and it was looking like I would be adding a lot of lead to the stern. So I put it in the pool with the battery on the deck behind the cabin and its sits about an inch deep in the water at the stern. If I decide to place the battery on the deck I'll have to make a box/shrimp sorter over it.
ID:	1656497   Click image for larger version
ID:	1656498   Click image for larger version
ID:	1656499   Click image for larger version
ID:	1656500   Click image for larger version
ID:	1656501   Click image for larger version
Old 09-02-2011, 01:07 PM
  #149
wayne d
wayne d's Avatar
And here is the rear structure mocked up.
ID:	1656519   Click image for larger version
Old 09-02-2011, 01:40 PM
  #150
rblubaugh
I have only one question; is the battery in the way of the midships aft boom?  Or can you move the battery further aft and compensate with  lead ballast in the bow, putting it as low as possible (guess that's two questions)?
