Go Back  RCU Forums > RC Boats > RC Scale Boating
Reload this Page >
Scratch Built Shrimp Boat.
RC Scale Boating Enjoy rc scale boating? Talk about it here.
Old 09-05-2011, 12:04 PM
  #176
wayne d
wayne d's Avatar
Default RE: Scratch Built Shrimp Boat.
On the last post in the upper right hand corner click REPLY.
A text box will open.
type your text.
In the lower part of the text box in blue are two options.
BETA: Multi-File Upload with Progress Bar!
AND
Click here to upload images and files!
I like the BETA one.
After the text is typed click one of those and another box opens to upload the pictures.
Once finished it will state FINISHED, click on that.
Then click OK at the bottom of the normal text box and your finished.
Old 09-05-2011, 12:13 PM
  #177
wayne d
wayne d's Avatar
I have been raising the boom up and down by hand and something had been bugging me. The cable that goes from the top of the rigging to the end of the boom. The cord is Kevlar fishing line.
Heres the problem: when the boom is raised the cord/cable becomes slack and just kind of hangs out in the breeze or does not lay flat up against the rigging.
So to solve that I took 2 small fishing split shot sinkers and crimped them on the line. Problem solved. Now when the boom is raised the cord/cable lays up against the rigging.
ID:	1658620   Click image for larger version
ID:	1658621   Click image for larger version
ID:	1658622   Click image for larger version
ID:	1658623   Click image for larger version
Old 09-05-2011, 12:17 PM
  #178
redmichaelgriffin
ok lets see if this work lol!!
Old 09-05-2011, 12:23 PM
  #179
redmichaelgriffin
here are the pictures of the shrimp boat i took for you.
ID:	1658642   Click image for larger version
Old 09-05-2011, 12:25 PM
  #180
wayne d
wayne d's Avatar
IT WORKS.............
Old 09-05-2011, 12:27 PM
  #181
redmichaelgriffin
I took like 20 they all wouldnt up load i may have to do it one or two at a time
Old 09-05-2011, 12:29 PM
  #182
wayne d
wayne d's Avatar
Depending how big the file size is, 3 or 4 will normally work using the BETA version.
  #183
redmichaelgriffin
some more pics
ID:	1658647   Click image for larger version
ID:	1658648   Click image for larger version
Old 09-05-2011, 12:31 PM
  #184
wayne d
wayne d's Avatar
I'm Sitting on the edge of my seat hitting the refresh button.
  #185
redmichaelgriffin
more pics
ID:	1658650   Click image for larger version
ID:	1658651   Click image for larger version
Old 09-05-2011, 12:34 PM
  #186
redmichaelgriffin
more
ID:	1658653   Click image for larger version
ID:	1658654   Click image for larger version
Old 09-05-2011, 12:36 PM
  #187
redmichaelgriffin
more
ID:	1658666   Click image for larger version
ID:	1658667   Click image for larger version
Old 09-05-2011, 12:39 PM
  #188
redmichaelgriffin
more
ID:	1658669   Click image for larger version
ID:	1658670   Click image for larger version
Old 09-05-2011, 12:42 PM
  #189
redmichaelgriffin
more
ID:	1658672   Click image for larger version
ID:	1658673   Click image for larger version
Old 09-05-2011, 12:45 PM
  #190
redmichaelgriffin
more
ID:	1658675   Click image for larger version
ID:	1658676   Click image for larger version
  #191
wayne d
wayne d's Avatar
Shrimp boats are busy places. This build may take a little longer than first thought.
Old 09-05-2011, 12:54 PM
  #192
redmichaelgriffin
thats all of em if you need some more detaled let me no the one named Harbor Light is ours the other one is an acual solid fiberglass ours is fiberglass over wood kinda like you are doing lol the make of them are desco one is a 73ft one is a 78ft Iforgot to ask when you did your motor for the shrimp boat did you change your prop size and your reduction for power not speed or is that an issue in the rc world thats the kinda things i dont know i do on real boats of coarse I dont think caterpillar maks an rc motor tho lol!!
Old 09-05-2011, 01:08 PM
  #193
wayne d
wayne d's Avatar
Hey Michael
THANK YOU very much for the photos. I've got a lot more work to do after seeing the pictures.
The motor, I bought from Harbor Models.
its an 800 series. We thought about a gear reduction, but running a 2" prop didn't think it would be any help. I'll just have to use throttle managment. Thats actually something I like to do with the lobster boat. I turn the throttle trim all the way up and I never have to even touch the trigger/throttle and I just put put around.
Old 09-05-2011, 01:18 PM
  #194
redmichaelgriffin
No problem believe me im sure i will be asking alot of questions I can all the pics you want i think ima order my motor and all today what about stearing and all that do you need a specific one to go with a specific remote and i think ima put a few more batteries for balast if you had two in the 30 then on a boat 10" bigger ithink you could do at least two more that and i gues you order your shaft and all after you lay out the kill and get a mesurement im going back offshore in about a week for 28 days so when i come back i will have two weeks to build if i can go ahead an order stuff . My wife is going to miss me for real when i start this project lol!!
Old 09-05-2011, 02:32 PM
  #195
wayne d
wayne d's Avatar
Give me a little time and I'll post some links for all the stuff.
Old 09-05-2011, 03:35 PM
  #196
wayne d
wayne d's Avatar
Here is the motor, 800 direct drive motor
http://www.harbormodels.com/site08/motors.htm
Here is the stuffing box.
3/16" Shaft and Stuffing Box
http://www.harbormodels.com/site08/m...ion.htm#shafts
Battery
I am using a Hobbico Torqmaster Mini Maintenance-Free Sealed lead acid 12 volts, 4.5ah
Transmitter is, well up to you. For a simple boat with throttle and steering only, a pistol grip radio works great. Bob found them for me for $15.00 each. If you have any more items that function then you will need a different radio with more channels.
Old 09-05-2011, 04:05 PM
  #197
redmichaelgriffin
Thank you man that helps alot Im fixing to order some wood I belive im going to go with 1/8x1/4 so it looks like real planks plus i just dont see how yal form those wide planks around those sharp bend anyway thanks alot for the help
  #198
rblubaugh
Wayne,
How about using a 1/4 oz. slip sinker for that "stay" cable (I think that's what Michael called it) to make it lay flat against the rigging? It could be a round one or torpedo shaped; round would probably work, and look, better. You could even paint it.
Bob
Old 09-05-2011, 04:17 PM
  #199
redmichaelgriffin
Look at em using that shrimping terminology lol. That would work or if you want somthing fixed you could even use somthing like a fishing swivel in the middle its what ever you perfer on that
Old 09-05-2011, 04:40 PM
  #200
wayne d
wayne d's Avatar
ORIGINAL: rblubaugh
Wayne,
How about using a 1/4 oz. slip sinker for that ''stay'' cable (I think that's what Michael called it) to make it lay flat against the rigging? It could be a round one or torpedo shaped; round would probably work, and look, better. You could even paint it. [img][/img]
Bob
That would work, This is what I had around the house. I'll put that in the memory bank.
