Pt 109
I’ve recently acquired a ProBoat PT 109 40 EP. It is 40” in length and has twin screws, the esc as well as the motors are water cooled, at least they’re supossed to be but there is no water flowing thru ether one from the rudder ram pickups.
I have carefully shot compressed air thru the cooling system of both the motors coil cooling loops and the esc and all seems clear with no clogs. Even at full throttle, no water exits the side mounted dump ports. Has anyone come up with a solution for this ?
I’m not very experienced running R/C boats, more into planes but this model is really detailed and I dig it! Also is there a way besides repowering it to make it a little faster? It is running on two 7.2 Venom 3300 NiMH packs. Thanks, Phill.
Go to a higher pitch prop. But you do need to get that cooling figured out because a higher pitch prop will put more load on the ESC and motor. Perhaps your pickup lines aren't installed correctly.
Yes, but the better way is to have the pickup in the right place and facing the right direction.
Also, not much point in a series arrangement - using the cold water to pre- heat it with the motor makes a heater for the ESC, and vice-versa.
I would put a "ram pressure" pick up for each item(this could also be one for every two if you run more than one shaft with it's own motor and ESC) to be cooled close to the stern. Obviously, these would need to be through the bottom of the boat to make sure they are always in the water.
