Dumas C C Super Sport bow
I'm building this kit and ran into a small issue with the bow deck fitting. The bow light base is flat, the deck is slightly arched so it doesn't sit right. Those who built this, how did you correct for it? I assume the full scale one is flat, but shaped so that it blends well with the planks. The planks are also thinner than the plastic spacers which happen to be the same thickness as the bow light base.
