landing craft
RE: landing craft
Are you looking for open deck landing craft, or the landing ships?
http://floatingdrydock.com/ Has many plans for both.
Check out their TFW series of plans under LANDING CRAFT
http://floatingdrydock.com/TFW2.htm#TFW
And check for matching hull lines.
http://floatingdrydock.com/HULL.htm
Or use a combination of similar classes of ships/craft plans and hull lines to get what you need to build the ship you want. Once you get the plans, they can be enlarged or reduced to produce any size model you want.
[8D]
[8D]
RE: landing craft
Hi Rye,
Look on ebay for LSU-1466. 2 sheet plans are from Great_plans and go for $19.50 plus shipping. I am in the process of building this boat, and have been looking for more details on the rudder tunneling arrangement. The original article was designed and built by Walter Musciano, he put an RC tank on it and when he "landed the boat" he drove the tank off.
Regards Jeff
Regards Jeff
My Feedback: (10)
RE: landing craft
hi
well it floats and goes great in rough waters but ramp door sticking ,got that fixs lead tank die on ramp bad battery fix that ,very rough water labor day morning though it would be like d-day took movie in black and white ,atfer tank die on frist run try it again with good tank, got out there water over the sten got the recvier wet boat die so its drying out will try again this weekend until then heres the frist vedio frist time in the water,will postnew one if she goes this weekend thanks rye
http://www.youtube.com/watch?v=-EAAi...e=channel_page
RE: landing craft
