Chris Craft help needed
I have made this request before, but didn't get the kind of help I need. I do have experience building RC models (but only planes and nitro hydros). Never anything like the Chris Craft. I am now at the point where I need to start the planking. I have NEVER done this before (I know, I should have built a Miss Unlimited). Anyway, when I asked before I got links to time elapsed build videos where 1 second I would see like 5 planks, then 10 seconds later they would be fiberglassing the boat. I even got a link to people building a full size boat!! Let me be clear. I do not know how to approach this at all!! Do I use epoxy, CA, or wood glue? Do I glue one plank at a time or do groups of about 5 or so? Do I wet them and force the contour or shape pieces to fill it. Do I start in the middle of the hull and work out, or visa versa. Do I line up according to the transom or stern? Told you! I NEED HELP!!! Please help!!!! There's a bag of M&M's in it for you (WITH NUTS!!!)
Thanks |
Hi Fleece3
I use CA clue as it sets quick. Have you had a look at plank on frame ships maybe on YouTube, there is a lot of videos and some can run for 30min. That should give you a good idea on how you go about doing the planks on the frame of your chris craft. hope that helps cheers |
Originally Posted by sde
(Post 12567700)
Hi Fleece3
Just a note that you only need to start one thread per question. I left this one since its the most appropriate place and already has replies.
Thanks |
| All times are GMT -8. The time now is 08:45 AM. |
