Do you know what electric motor this is?
1 Attachment(s)
Hi, would you happen know what the "particulars" of this made in China H T I motor ? How can I tell if it is a stock 27 wound motor ? It is 6 too 12 volt ? Would you help me find the website for HTI ? Diameter is 4.2 mm OR 1 5/8". Motor itself is 7.5 mm long OR 3" long, not including the 5mm shaft. Shaft itself is 3.1 mm long OR 1 3/16" long. Photos enclosed. Thank you, Skip
RE: Do you know what electric motor this is?
w
Web Site
http://www.htimotors.com/doce/p1.html Model Current - RPM HTBRR04206705B-0002 12 - 4750 0.6 3750 3.15 497 6.9 12.65 2360 32.8 6-15 67 |
Thank you for your help, much appreciated ! Skip
Hi, the only difference I see is, that mine has -0001 at the end of the number, and the spec sheet has -0002 at the end of the number. Would you tell me what the difference is? Thank you, Skip
A lot of those motors are custom made for different manufactures of products. If it doesn't show up on a spec sheet, then you would have to contact the manufacture directly. A lot of times they won't give out the information because it is priority only. Meaning you can only get the info from the end user, if even they will tell you who it is. A lot of times it could refer to a different placing of the screw holes, reversal of the motor leads, etc.....
Hi, thank you for your help, Skip
| All times are GMT -8. The time now is 06:11 PM. |
