RCU Forums
-   RC Scale Boating (https://www.rcuniverse.com/forum/rc-scale-boating-103/)
-   -   Newbie rudder question ?? (https://www.rcuniverse.com/forum/rc-scale-boating-103/4207233-newbie-rudder-question.html)
mitchlandry 04-25-2006 10:24 PM
Complete boat newbie here.
When building the hull, is anything done extra for the rudders to attach to the hull for water intrusion?
I know the prop goes through the stuffing box, is there something similar to use for the rudder?
Or does water not typically creep up the ruddershaft through the bushing in the hull?
LtDoc 04-26-2006 02:34 AM
RE: Newbie rudder question ??
Mitch,
The rudder and stuffingbox/driveshaft are both treated about the same. Either some type of grease/oil, and/or maybe a small 'O' ring at the top under the control arm. If the top of the rudder tube is below the water line there will be some leakage unless something is done to prevent it (back to the oil/grease/'O' ring thingys). There can be leakage even if the tube extends above the water line due to the water flow from the prop. Same answer as before. As long as you don't cause the servo(s) too much additional 'work' you can go about sealing a rudder tube any way you want or can think of. A small bit of water isn't very threatening if you remove it. More than a little bit means something should be done.
- 'Doc
PS - It's a 'known' fact that scantily clad ladies, wearing hula skirts, dancing around your boat will 'cure' the problem. If you resort to this method, please post pictures.
