Need help with U-joint please.
1 Attachment(s)
Slowly I'm getting the parts for my first boat (scale) and I need help with finding a U-joint for my 550 motor.
I have installed a gear box 2.5:1 ratio to slow down the speed. The problem that I have is the output shaft form the gear box is much larger than the prop shaft and I need a U-joint that has different size holes. Here are some info since I don't know the shafts sizes: -motor and prop shaft from a Great Planes Stinger boat. -gear box from Great Planes model GD-600 Attached are a few pics of the parts. Thanks. |
RE: Need help with U-joint please.
Graupner has u-joints that can be gotten with different size ends, metric and standard. If they don't have what you need then the ends can be mixed/ matched to get what you need.
| All times are GMT -8. The time now is 10:48 PM. |
