Tug visor
Whats the gimmic to cutting a single piece tug boat visor? I'm trying to do this with manila envelopes so that I dont waste my Plastruct sheets. Cant seem to get it right. Help!! Thanks.
RE: Tug visor
1 Attachment(s)
Is this a conical section, or an annoying elipse?
This is some cardboard mockups I created before cutting the deck rails for the Fire Boat. I basically cut the rough shape, and then add 1/4"-1/8"- or 1/16th of an inch to top or bottoms till I get what I want. Usually takes two or three tries. If it is a simple conical section, and you know the small and large diameter and the hieght of the cone, then you can use the "Shroud Calc" http://www.realmcommunications.com/r...shroudcalc.htm [8D] |
RE: Tug visor
2003merc,
I hate to be an idiot, but what's a 'visor'? - 'Doc |
RE: Tug visor
ORIGINAL: LtDoc 2003merc, I hate to be an idiot, but what's a 'visor'? - 'Doc http://www.uscg.mil/reserve/magazine...mages/Tug1.jpg |
RE: Tug visor
Okay, now I understands.
- 'Doc |
RE: Tug visor
Kinda like a duck bill only placed higher. >G>
Tug ORIGINAL: LtDoc Okay, now I understands. - 'Doc |
RE: Tug visor
thanks Umi. I've been following your fireboat build and its the first site that I turned to to try and git some ideas. I've been using the manila and have almost got where I need to be. I'll let you all know how it works out. Thanks.
RE: Tug visor
i built a bow visor buy making a light weight wire frame from floral wire and the glueing 20 bond typing paper to the outside and then removed the paper clad wire frame from the bow, flattened it out and traced it on craft card,,,worked well
RE: Tug visor
DO you have pictures? That would help greatly. Thanks, Reddog69
RE: Tug visor
1 Attachment(s)
heres the basic idea for using a wire frame for getting the correct shape to cut out your visor,this method can be used for almost any conical shape,,,,,,
| All times are GMT -8. The time now is 07:25 PM. |
