RCU Forums
-   RC Scale Boating (https://www.rcuniverse.com/forum/rc-scale-boating-103/)
-   -   Scale rivets (https://www.rcuniverse.com/forum/rc-scale-boating-103/5694423-scale-rivets.html)
hover Tim 04-10-2007 01:24 PM
Scale rivets
hi
Does anyone know how to create this effect on timber
LtDoc 04-10-2007 03:20 PM
RE: Scale rivets
Tim,
Probably the most common way is by putting a small drop/drip/dab of sort of thick CA where you want a rivet. A few of the more uncommon ways are to mark each rivet exactly, then sand everything away from it (very uncommon). Or make the rivets then glue them on (uncommon, unless the rivets are pretty good sized things). Then paint, stain, or cover the whole mess with something.
- 'Doc
benny2.0 04-10-2007 04:25 PM
RE: Scale rivets
the air plane gys might know
Papower 04-11-2007 07:40 AM
RE: Scale rivets
Tim, Here is what you want. http://www.starwoodmodels.com/products/ssm/rivetkit.php
Bruce
dauntlessfan 04-11-2007 08:41 AM
RE: Scale rivets
Also check for advice on the websites out there about building the Nautilus. That little sub has thousands of 'em.
rye 04-15-2007 08:30 AM
RE: Scale rivets
hi i scatch build planes and i use a squeeze bottle with glue try before on a junk piece frist, or if it soft wood i use a sewing maker or cutting wheel it works great, then exopy lite over it ,you may have to make them deep if you are going to do it this way but you get a beautyful roll of rivets rye
