5mm to 3/16th joints
I am using a Grapner 700 with 5mm shaft and want to connect to a 3/16 prop shaft. I would like different opinions on the best way and cheapest way to go. Thanks, Randy.
RE: 5mm to 3/16th joints
Best way: Raboesch u-joint with end sizes you need to fit. They are available in many sizes.
Cheapest way: Get a piece of aluminum rod and drill your own holes. |
Kmot. do you know of a U.S. company that has the 5mm to 3/16 u-joints.
