RCU Forums
-   RC Scale Boating (https://www.rcuniverse.com/forum/rc-scale-boating-103/)
-   -   M tronicks (https://www.rcuniverse.com/forum/rc-scale-boating-103/6314417-m-tronicks.html)
hover Tim 09-01-2007 10:21 AM
M tronicks
hello
Just starrted to wire up the hovercraft using Mtronicks ESCs ive got a forward and reverse for the thrust and a forward only for the lift i tried to wire up the thrust for some reason the i can only go backwards then theres no control forwards just full throttle and no stop eaither so is there an easy way to set these up
Regards Tim
Umi_Ryuzuki 09-01-2007 12:41 PM
RE: M tronicks
Perhaps the ESC is set up for forward only.
Reverse the wires at the motor, and re set the ESC?
Actually, maybe you could flip the servo reverse switch on the transmitter, then the ESC would be providing the correct forward thrust, per the stick movement, and then you can reset the ESC as per instructions.
